1.45:1 rear gear ratio? - JeepForum.com
post #1 of 4 Old 01-11-2005, 03:08 PM Thread Starter
fromme
fromme's Avatar
Either I have some jacked up gears or I"m not doing something right, but I was trying to determine what my gear ratio is. For 1 rotation of the tire, my rear driveshaft rotates 1.45 times. I doubt there is such a ratio that exists, am I missing a formula or something.
One more question, what does it mean if I rotate one tire and the other one doesn't move either forward or backward?
2003 TJ Rubicon, 3" Zone lift, 33" Mickey Thompson MTZs, 4.88s, Warn Zeon 8S winch
fromme is offline
post #2 of 4 Old 01-11-2005, 03:40 PM
plain76cj5
If you spin one tire and the other doesn't move, it means you have an open differential (not limited slip). Also, when trying to determine your rear diff ratio, if you spin one tire and the other doesn't move the spider gears are actually halfing the speed of your driveshaft. More than likely you have a 2.73 or a 3.08 rear diff ratio. You can have someone try to turn the other tire at the same speed as you turning your tire, and then count the driveshaft revolutions. The best way is to remove the diff cover and count the teeth of the ring gear and the pinion gear to get the ratio. #of ring gear teeth/ #of pinion teeth. Most ring gears have the ratio or the tooth count stamped on the outside edge.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline
post #3 of 4 Old 01-11-2005, 03:45 PM
jeepskate
Tape a piece of string to your driveshaft and put a tape or chalk mark on the driver side rear tire. Hop in, look at the rear tire, and drive forward one revolution. Hop out and check your string. You probably have 2.73's. There should be tags on your diffs as well. Obviously pulling the cover is *the* way to find out, but the other methods will get you in the ballpark.
jeepskate is offline
post #4 of 4 Old 01-11-2005, 03:55 PM Thread Starter
fromme
fromme's Avatar
Thanks guys, that helped. I need to confirm I had the 2.73, and unfortunately I do.
fromme is offline
1976 CJ7 rear end gear ratio. PIPER-68 Jeep CJ Forum 7 09-10-2009 08:15 AM
gear ratio? Pfeifferj Jeep CJ Forum 6 03-30-2009 10:06 PM
84 CJ7 gear ratio garoughrider Jeep CJ Forum 12 03-24-2007 05:54 AM
Rear end gear ratio 84cj7 steve84cj7 Jeep CJ Forum 2 02-02-2005 08:58 PM
)))))rear gear ratio?((((((((((help! 2cjs Jeep CJ Forum 11 02-25-2002 06:20 PM
