Washer fluid change - JeepForum.com
 3Likes
  • 1 Post By Kruzin
  • 1 Post By Kruzin
  • 1 Post By Indy
post #1 of 7 Old 10-18-2019, 10:19 AM Thread Starter
Ingebelle
2011 FSJ Cherokee
Washer fluid change
I wish to use RainFX fluid for the washer fluid. How do I get the old fluid out the simplest way?
Inge
Ingebelle is offline
post #2 of 7 Old 10-18-2019, 11:00 AM
jtec
jtec's Avatar
2014 JK Wrangler
add the rainX to current fluid, my experience it does not work as expected till the second bottle of rainx so don't expect instant results. but well worth the extra price.
jtec is online now
post #3 of 7 Old 10-18-2019, 12:23 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Press the washer button in your vehicle and hold it till the reservoir is empty.
Or just do what jtec said, there's no harm in mixing washer fluids.
dln1962 likes this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 7 Old 10-18-2019, 12:33 PM
222Doc
222Doc's Avatar
could use suck pump, siphon tube.
222Doc is offline
post #5 of 7 Old 10-18-2019, 12:58 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Turkey baster.
222Doc likes this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 7 Old 10-20-2019, 09:13 AM
Indy
Indy's Avatar
Inge
Go to your local parts store and buy a generic 12v fluid pump. It shouldn't be more than $75. Then go to lowes or home Depot and buy a length of 1/4" tubing, $4. Then to your local electronics store and get some wire and large alligator clips, about $10. You'll be all In for less than $100 after tax.
Go home and put everything together, snake the tube to the bottom of the reservoir, attach the gator clips to your battery and let it pump all the liquid out.
As a pro tip, if you attach another length of tubing to the output of the pump you can probably redirect it onto your windshield and wash your windows at the same time. It will be more effective if you also run your windshield wipers.
For about $5 you can get some rope to tie to the wider blades. Cut the rope in half and attach 1 piece to either blade. You'll need 2 friends for this part. Take the output hose from the fluid pump and aim it at different parts of the windshield while your 2 friends use the ropes to pull the wiper blades back and forth.
Now doing this while youre on the freeway gets a little tricky. you'll need a fourth friend to drive and a few rolls of duct tape...
MikeyDeezy likes this.
I'm the only gay eskimo.
Indy is offline
post #7 of 7 Old 11-04-2019, 11:17 AM
dln1962
Junior Member
Plenty of good suggestions about how to solve the problem but I'll just add that I used to use the RainX stuff and quit because it seemed to attract crud to the windshield. When it hasn't rained and the vehicle hasn't been washed for awhile, it seemed to make the wipers streak and smear really badly when Mr. Rain did come along. Went back to the old blue stuff and the effect went away. YMMV, as always.
dln1962 is offline
