Tracking / steering issues - JeepForum.com
post #1 of 10 Old 08-04-2019, 10:32 PM Thread Starter
bradleyheathhays
bradleyheathhays's Avatar
My '11 Crown Vic has got 315k miles on it and I'm having some kind of tracking problem that I think is coming from the steering. If there's not much wind it drives straight down the road just fine up to about 60 mph. But if the winds up some, or if I take it up to 70, it's tracking characteristics start to get weird and unsettling. Rain seems to cause it to get worse as well. The feeling is not dissimilar to hydroplaning.
I got the wheels off the ground and pushed/pulled on all the tires..3 and 9 o'clock, 6 and 12. Back wheels were solid, and the fronts were ok when I did the 6 and 12, but on the 3 and 9 test the tires moved about 1/4". They didn't move easily say as if they were completely loose, but it didn't take all that much effort to get them rocking either. At each limit of movement there's a low grade thud that's coming from somewhere between the two wheels, pretty close to the center of the car I'd say. I don't know if the movement I'm seeing is normal, but the degree the steering seems to be unpredictable would seem to correlate to about the degree of movement I'm seeing with the 3 and 9 test.
Any ideas on where I go from here?
~~_/) ~~
bradleyheathhays is offline
post #2 of 10 Old 08-04-2019, 11:18 PM
mukluk
mukluk's Avatar
Have a person slowly turn the steering back and forth from lock to lock while you observe all the steering and front suspension components for wear and play. Good chance you have worn tie rod ends, though worn suspension bushings may explain why the situation seems to be worse at higher speeds. Low tire pressure can also cause the problems you describe, as can an alignment that's out of spec.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 10 Old 08-13-2019, 04:46 PM Thread Starter
bradleyheathhays
Thanks for the good advice and sorry it took so long to get back. I just got the car back from a front end inspection and they're saying my biggest problem is that both lower ball joints need to be replaced. I've done work similar to this before (using a pickle fork to separate joints and using a rented ball joint press) but they were advising it might be too tough of a job to do by myself in my driveway. I have a 1000lb impact wrench but only a really small compressor.
What do you guys think about attempting this job myself? Any advice?
~~_/) ~~
post #4 of 10 Old 08-13-2019, 06:49 PM
222Doc
222Doc's Avatar
i was thinking Bjs myself. Im not familiar with crown suspension. If its like say my 71z28. the main issue doing bjs on these is that spring is under a TON of pressure and you need spring compression tool. its some what a hazardous job. if that spring lets loose a world of pain can follow, even kill you. but i have done them and jeeps. I bought a GOOD Bj C clamp tool set was not cheap.
a tip; when you get to that point you pressing it out dont over tighten the C press once its at about its max force. tap Cs or A arm with a brass hammer. the shock will do the rest on the stubborn ones. if this has stamped A arms be careful not to distort it.
222Doc is offline
post #5 of 10 Old 08-15-2019, 12:51 AM Thread Starter
bradleyheathhays
I think I have struts so I should be ok. Tried compressing the springs on my Cherokee one time and had a close call. That was enough for me.
I've decided I'm gonna give it a shot at doing this myself. 'Couple' questions...
- I know the lower BJ presses out, but does the top one press out as well?
- Does the sway bar link have to come off for better access?
- Anything else I should change out while I'm in there? So far I'm gonna be doing both upper and lower BJs and probably the tie rod ends.
- I've been told to use green loc tite. That would be used on the threads on the bottom of the BJs?
- The Moog BJ I'm considering at Rockauto doesn't appear to have a grease boot. Am I looking at this picture wrong? Is that black part a boot that will expand when it's filled up?
~~_/) ~~
post #6 of 10 Old 08-26-2019, 11:12 PM Thread Starter
bradleyheathhays
Do I have a stamped steel or forged top A-arm? I believe it's stamped but I'm not entirely sure.
~~_/) ~~
post #7 of 10 Old 08-27-2019, 04:13 PM
Fourtrail
1974 CJ6
Stamped. May as well get a complete new forged arm with the balljoint already in it as the rubber bushings at the frame are likely shot also.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #8 of 10 Old 08-29-2019, 03:21 PM Thread Starter
bradleyheathhays
Considering the mileage I've decided to change out everything I can. Ordering 2 new top A-arm assemblies, 2 lower ball joints, 4 lower A-arm bushings, 2 new strut assemblies w/ springs, and 2 sway bar links. This only leaves the tie rod ends which there is a chance are not original. This car was part of a fleet that got regular maintenance so since I didn't see any movement at the outer tie rod ends when I was doing the 3 & 9 push test I'm thinking they may have already been replaced. I'll put in everything I've ordered and see how the steering is after that. Do you always do both inner and outer tie rod ends at the same time or is it common just to do the outer, or just the inner?
Found a decent set of ebay shock and spring, strut? assemblies for $150 but it's specified as fitting the interceptor model whereas mine is just the base model. Would they still work ok?
~~_/) ~~
post #9 of 10 Old 08-29-2019, 04:24 PM
Fourtrail
1974 CJ6
interceptor likely has a different spring rate and may sit a bit lower. should be a decent handling upgrade with the interceptor strut package. be sure to get a quality alignment after putting on the new struts and a-arms as camber/caster will need to be adjusted back into spec.
post #10 of 10 Old 09-13-2019, 07:28 PM Thread Starter
bradleyheathhays
Found a fairly comprehensive front end kit for a great deal...like $137 for all of this...
2006-11 Ford Lincoln Mercury Steering & Suspension Kit 12 Piece Set - 1ASFK05040
https://www.1aauto.com/2006-11-ford-...t/i/1asfk05040
I'd rather go with something more dependable like Moog at least on the lower ball joints.
What do you think? Should I go with this kit and save? She's got 320k on her now.
~~_/) ~~
