Problems with Window Bolt not Unscrewing - JeepForum.com
post #1 of 2 Old 04-25-2020, 03:53 PM Thread Starter
Mister_Assister
Mister_Assister's Avatar
1993 XJ Cherokee
I was attempting to replace the driver's side front power window motor and regulator on my '93 Cherokee country. The motor does not work but I managed to get the widow down low enough on the door to where I could easily see where the window was attached to the regulator. On my particular set-up, the window is connected to the regulator by one medium sized, brass, six-pointed star pattern bolt that goes through a hole in the window. When I went to unscrew the bolt, the thing turned fairly stiffly but would not actually loosen. I would turn it and turn it but it wouldn't unscrew just spin in place. I felt the back of the thing and there isn't any nut behind it, just the end of the bolt and a flat, washer-like disc thing up against the window that spins with the bolt when I try to unscrew it. I've tried holding onto that disc but with so little room inside the door it's impossible for me. I've watched a ton of videos and scoured this forum but I cannot find a similar thing happening during a fix like this. If anyone has any suggestions I would be very happy to hear them.
Mister_Assister is offline
post #2 of 2 Old 04-25-2020, 05:21 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You should be able to remove the window regulator bolts and wiggle the mechanism around inside the door shell to get the window glass to move down more. IDK if 1993 is like 1996+ but I have always been able to get a pliers to grab the retainer the TORX bolt threads into located on the other side of the glass. Perhaps you need an assistant.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
