Problem w/ intermittent defrost a/c - JeepForum.com
post #1 of 7 Old 03-09-2019, 04:23 PM Thread Starter
bradleyheathhays
bradleyheathhays's Avatar
Have a '11 Crown Vic with 290k miles and I've been having a problem with the windows fogging up all the way around. The defrost seems to be working about half the time. On humid rainy days it'll work for say a half hour keeping the windows clear, then the windows will fog hard for 10-15 mins. And then it might decide to start working again, back and forth it goes. When I started it just now the compressor clutch turns when the a/c is turned on, although I haven't had a chance to observe it when the windows are fogging.
A secondary problem it has is that it only blows air through the vents on the front of the dash, straight out into the cabin. The air flows only very weak out the defrost vent at the windshield or the floor. It does this on all settings. Although this might contribute somewhat to the problem, it seems like the a/c does completely cut out as the windows will still fog hard with the a/c set to on and on full fan. When it cuts off the air in the cabin feels immediately humid. One that that helps somewhat is to turn the temp toward cooler and it seems to not fog as much and gives it a chance to maybe clear the fog some.
Any idea what's causing this or what I should do to start testing?
~~_/) ~~
bradleyheathhays is offline
post #2 of 7 Old 03-10-2019, 08:33 AM
jtec
2014 JK Wrangler
are you WAY of topic and forum - Crown Vic as in FORD?
jtec is offline
post #3 of 7 Old 03-12-2019, 06:20 PM
Devil15
And wasnt this asked and answered on pirate4x4.
Sent from my SM-G892U using Tapatalk
Devil15 is offline
post #4 of 7 Old 03-31-2019, 03:43 PM Thread Starter
bradleyheathhays
Yes, thank you. This is why put this in the General Discussion forum. Wanted to tap into the expertise of the people here.
Any ideas please?
~~_/) ~~
post #5 of 7 Old 04-04-2019, 09:10 PM Thread Starter
bradleyheathhays
I'm gonna assume my problem is being caused by low refrigerant and take a shot at fixing it as cheaply as I can. But at the same time I'd like to take steps at identifying where the leak might be.
So what will this look like? Renting some gauges from the local car store and checking my refrigerant lines? How would you go about this and what readings should I be looking for?
And then if things read low I would get a can of refrigerant with leak revealing dye and put it in the system?
Sorry I'm so remedial here, first time working on an a/c system.
~~_/) ~~
post #6 of 7 Old 04-07-2019, 03:05 AM Thread Starter
bradleyheathhays
Hooked the gauges up and it seems like I've got a low refrigerant condition. Before turning the engine on both gauges read about 75. After starting the engine and setting the AC on max you could really tell the compressor was cycling fast. The needles cycled every 5-6 seconds...one going up and the other down, then reversed. The blue gauge cycled between 22 and 38 PSI while the red went between 90-140. The outside temp was about 60 F.
From what I've read, especially with the compressor cycling so fast, this indicates low refrigerant. Hopefully my compressor isn't hurt by running it for so long like this.
How do I go about using this 2 gauge setup to add refrigerant? Should I add it through the middle hose somehow or get a can of 134 with a gauge on it and just add it directly from the can?
And how do you know how much to put in?
~~_/) ~~
post #7 of 7 Old 04-09-2019, 12:46 PM Thread Starter
bradleyheathhays
After I took the gauges off I noticed one of the schrader valves was hissing, and now the system is down to 0 psi. So I believe a faulty valve has been the culprit all along.
Now that the system is down I'm going to replace both valves, but my regular schrader valve removal tool won't fit down on the valve. The stem of the valve is too long and the tool won't go down around it to twist it out. I need a tool with prongs longer to fit down into the recessed sides of the valve. Does this '11 Crown Vic have schrader valves or a different kind of valve?
Also, when I go to fill the system with refrigerant, do I need to add any PEG oil or just add refrigerant up to the specified capacity?
~~_/) ~~
Gas pedal a/c problem Red88 JK Wrangler Technical Forum 2 01-08-2019 06:52 PM
CRD PCM rubbing wire issue and A/C problem DieselForTwo WK Grand Cherokee & XK Commander Forum 6 06-06-2018 07:59 PM
Intermittent starting problem webspyyder WK Grand Cherokee & XK Commander Forum 4 04-11-2018 07:53 PM
A/C defrost blower switch 2001 Cherokee Dockgsp General Jeep & Off-Road Equipment 4 03-14-2018 07:32 AM
Intermittent Idle Problem 5.2L 97 Shooter-Mcgavin ZJ Grand Cherokee Forum 5 03-08-2018 09:36 AM
