Prevent Rust on Newly Bare Metal - JeepForum.com
 2Likes
  • 1 Post By Fourtrail
  • 1 Post By Jeff88
post #1 of 11 Old 01-26-2019, 05:46 PM Thread Starter
A3M0N
A3M0N's Avatar
I was gifted a well loved Craftman tool chest by a family friend. I'm planning to restore it to the best of my abilities, I have several of the drawers already stripped, rust removed, and painted. I'm moving on to the top cabinet now. There are several areas to strip before I can paint, but I don't want it to flash rust. Is there a paintable way to prevent flash surface rust on bare metal?
And while I'm here, if any of y'all have restored a toolbox, did you strip and paint the interior of the cabinet? You can't see it with the drawers in, so I was thinking about just cleaning it really good and spraying with rust converter and leaving it like that. I'll still strip and repair the outside.
Thanks!
2002 WJ / 4.0l / 2WD
A3M0N is offline
post #2 of 11 Old 01-27-2019, 04:31 AM
RockWoRM
RockWoRM's Avatar
Not sure what you mean by 'flash rust'? Yes, exposed raw metal can oxidize to an extent in a high humidity area. But if you clean it and then prime with a good metal primer immediately, then I wouldn't think it would be much of a problem.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #3 of 11 Old 01-27-2019, 10:46 PM Thread Starter
A3M0N
A3M0N's Avatar
I've been stripping the paint chemically, then bathing it in rust dissolver (phosphoric acid base). As soon as I rinse off the rust dissolver it gets a layer of rust before I can even get it dried all the way to prime it. Would rinsing the rust dissolver off with mineral spirits help hold off the rust?
A3M0N is offline
post #4 of 11 Old 01-28-2019, 09:04 AM
Fourtrail
1974 CJ6
First off, I would get a good dehumidifier running in the room that you are working in to drop the humidity level to slow down the flash rust. WD-40 is a good rust preventer that can be sprayed/wiped on as you are drying sections of the bare metal. Downside to WD-40 is you have to clean it back off before you paint. The below link is to a 'mega' penetrant/rust inhibitor that says it is safe/able to be painted directly over.
http://www.gibbsbrandlubricant.com/index.htm
A3M0N likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 11 Old 01-28-2019, 09:51 PM Thread Starter
A3M0N
A3M0N's Avatar
Well, it looks like I was using the rust dissolver incorrectly. The instructions on the bottle say to rinse the work piece after treatment, so I was rinsing the pieces with the garden hose then trying to dry them before rusting - not working. I went to the product website and watched a video, they just wiped the piece down with a damp towel. So I stripped and rust treated a relatively flat panel, then wiped the product away. Several hours later, no rust! I sand the really tough converted rust off and prime it tomorrow. So yeah, better directions, or I need some more common sense!
A3M0N is offline
post #6 of 11 Old 01-30-2019, 11:17 PM
RockWoRM
RockWoRM's Avatar
Lol. That makes a little more sense. It sounded like you were cleaning, by wire wheel, grinder, bead blast or what ever and getting the metal down to clean white. If left unpainted it will start to oxidize/rust again.
The chemical treatment can be a good alternative. The phosphoric acid will convert rust to iron phosphate and then can be sanded/painted as you have done.
RockWoRM is offline
post #7 of 11 Old 02-26-2019, 01:43 PM Thread Starter
A3M0N
A3M0N's Avatar
I finished the top box and figured I'd share a before and after with y'all. Thanks for the help!
A3M0N is offline
post #8 of 11 Old 02-26-2019, 01:46 PM
Jeff88
looks good, nice work.
A3M0N likes this.
Jeff88 is offline
post #9 of 11 Old 02-26-2019, 03:35 PM
vadslram
Orthophosphoric acid
Kind of a blue green watery acid. It will change the actual surface to ferrous II Oxide.
You can buy it at home stores and auto shops under names like Ospho 605.
Wipe it on and let it sit then wash off. It stops on bodywork, it should work on a tool box.
vadslram is offline
post #10 of 11 Old 03-02-2019, 08:06 PM
RockWoRM
RockWoRM's Avatar
Sherwin Williams paint Co. has an Ospho type rust treatment but have no idea what all is in it? Since it's Ca., most likely 99% water!
RockWoRM is offline
post #11 of 11 Old 03-04-2019, 08:31 AM
vadslram
It would be mostly water. You don't want the acid too strong. It is kind of the same as bluing a weapon. If you have the acid too strong it will discolor the metal, great for a gun but not needed for a fender.
vadslram is offline
Unibody rust, the never ending battle Rob K KK Liberty Forum 127 04-14-2019 04:32 PM
Rust Proofing bare frame mikewiz38 YJ Wrangler Technical Forum 21 08-01-2018 12:19 PM
Losing the Battle With Rust Willyc Jeep CJ Forum 16 05-08-2018 11:39 PM
New frame, how to prevent rust? Rynoman27 Wrangler General Discussion 8 03-07-2018 05:47 PM
