Need to rethread a plug hole from a blown plug - JeepForum.com
post #1 of 4 Old 02-12-2019, 01:31 AM Thread Starter
bradleyheathhays
bradleyheathhays's Avatar
Bought an '11 Vic with the 4.6L back in June and a few months back I tried to change out the plugs. All came out ok except for cyl 4 which only cranked out 1/4 turn. Had a shop take it out and they said they had to redo the threads. I've seen videos where you can remove a stuck plug by drilling into it somehow, but because this was in the 4 position and hard to get to I'm guessing they just power cranked it out. Not sure but I'm guessing those threads are compromised now.
Well, this past weekend that same plug blew out of cyl 4. Inspection reveals a coil and boot jammed up underneath the fuel rail and a plug that I fished out without any turning. When I go to install a new plug it just sits on top of the threads and turns without going in. So I guess what's happened is that the plug rotated most of the way out but when it got to the last couple threads the compression blew it out the rest of the way, and that it's just the top few threads in the hole that are damaged. Inspection of the plug reveals that most of the threads are intact except for the 2-3 that are closest to the element.
So my question is...should I try to fix this myself or just take it to a shop? Some kind of tap tool would probably fix it, but since it's the beginning threads that are boogered it'd probably have to start from the inside of the cylinder. I really don't have a clue as to how to approach this.
~~_/) ~~
bradleyheathhays is offline
post #2 of 4 Old 02-14-2019, 08:45 AM
vadslram
Helicoils are designed to fix exactly your problem. They aren't perfect but they are relatively cheap,and easy to put in yourself.
You can take the head off and bring it to a machine shop, They should be able to fix it but it will be quite a project.
vadslram is offline
post #3 of 4 Old 02-14-2019, 10:51 AM
XJ99
XJ99's Avatar
2019 KL Cherokee
If accessible, you could chase the damaged threads, but I'd worry
about metal shavings dropping in to the cylinder.
After re-reading your post, I'd take it back to the shop and tell
them what happened. Odds are they'll work with you. 0.02
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #4 of 4 Old 02-15-2019, 01:59 PM
Fourtrail
1974 CJ6
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
12 Hole Injectors-- INFO CobraMarty TJ Wrangler Technical Forum 19 06-08-2019 04:54 PM
Cruddy spark plug #1 xpage YJ Wrangler Technical Forum 23 01-09-2019 05:59 PM
cyl 7 misfire and coolant in the plug well bradleyheathhays General Discussion 5 11-15-2018 08:12 PM
Core Plug Block AMC 150/2.5 Longblock Jeep CJ Forum 4 03-20-2018 05:05 PM
Turn signal plug loose. Need a replacement or a fix propped1 JK Wrangler Technical Forum 2 11-27-2017 02:22 PM
