Help reading Jeep Wiring Schematics - JeepForum.com
post #1 of 7 Old 08-27-2019, 01:37 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
I'm not sure where to post this but...
I understand probably 3/4 of what's on the diagrams but there's a few things I don't. Is there a good complete primer somewhere that tells me what things mean? I understand symbols, it's just some of the wire designations that have me stumped. Specifically, things like this, examples:
A wire with the following written within it:
E2 -?
20 -?
OR (orange, I'm assuming)
and
(8W-45-10) - appears next to a module.
Thanks!
Experience. It's what you get when you don't get what you want.
A beaver without a pelt is like a peacock without feathers.
Memberships: California Association Of 4WD Clubs - Friends Of The Rubicon - The Blue Ribbon Coalition
K6CKR
Originally Posted by Grape Ape
How many times have we told you . DON"T DUMP THE BODIES CLOSE TO YOUR HOME!!
HVACman is offline
post #2 of 7 Old 08-27-2019, 05:02 PM
Fourtrail
1974 CJ6
Link to the diagram you are looking at?
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 7 Old 08-27-2019, 06:00 PM
mukluk
mukluk's Avatar
E2 is the circuit designation, 20 is the wire gauge, and OR is the colour (in this case orange, as you guessed). The 8W-45-10 reference is the wiring diagram (8W), system 45 (Body Control Module), sheet 10 -- it's telling you where more diagrams on the component in question can be found.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 7 Old 08-27-2019, 07:13 PM
jbolty
jbolty's Avatar
splices are marked also. This is from a 90YJ diagram
Splices
Splice A1: Behind LH Side Of Instrument Panel
Splice A2: Behind LH Side Of Instrument Panel
Splice A3: Behind LH Side Of Instrument Panel
Splice A4: Behind LH Side Of Instrument Panel
Splice A5: Behind LH Side Of Instrument Panel
Splice A6: Behind LH Side Of Instrument Panel
Splice A7: Behind LH Side Of Instrument Panel
Splice A8: Behind LH Side Of Instrument Panel
Splice A9: Behind LH Side Of Instrument Panel
Splice C1 (2.5L): LH Side Of Engine Compartment
Splice C2 (2.5L): Upper Rear Of Engine Compartment
Splice C3 (2.5L): On Firewall
Splice C4 (2.5L): On Firewall
Splice C5 (2.5L): LH Side Of Firewall
Splice C5 (4.2L): LH Side Of Firewall
Splice C6 (2.5L): LH Rear Side Of Engine Compartment
Splice C7 (2.5L): LH Rear Side Of Engine Compartment
Splice C10 (4.2L): On Firewall
Splice C11 (4.2L): On Firewall
Splice C14 (2.5L): On Lower LH Side Of Firewall
Splice C16 (2.5L): On Firewall
Splice C16 (4.2L): On Firewall
Splice C18 (4.2L): On Firewall
Splice C19 (4.2L): On Firewall
Splice C20 (2.5L): On LH Side Of Firewall
Splice C21 (2.5L): On Lower RH Side Of Firewall
Splice C22 (2.5L): On Lower RH Side Of Firewall
Splice C22 (4.2L): On Lower LH Side Of Firewall
Splice C25 (4.2L): RH Side Of Engine
Splice C26 (4.2L): RH Side Of Engine
Splice E1: Front LH Side Of Engine Compartment
Splice E2: Front LH Side Of Engine Compartment
Splice E3: Front LH Side Of Engine Compartment
Splice E4: Front LH Side Of Engine Compartment
Splice E5: Front LH Side Of Engine Compartment
Splice P1: LH Rear Side Of Interior
Splice P2: LH Rear Side Of Interior
SpliceP3: LH Rear Side Of Interior
jbolty is offline
post #5 of 7 Old 08-28-2019, 02:21 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
Thank You! This answeres my question.
K6CKR
HVACman is offline
post #6 of 7 Old 08-28-2019, 02:22 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
Thank you for the additional info! I appreciate it.
K6CKR
HVACman is offline
post #7 of 7 Old 09-13-2019, 03:48 AM
Jonny Jeep
Jonny Jeep's Avatar
Have a read of section 8W-01. All will be explained.
Jonny Jeep is offline
