is it even worth it to use locking lug nuts - JeepForum.com
 1Likes
post #1 of 19 Old 06-06-2019, 07:35 PM Thread Starter
Kluk Ztopolovky
Hello, I hear many people do not bother anymore getting the locking lug nuts installed on their wheels due to the fact that nowadays one can buy a socket that will remove them anyways. What is your opinion? Thanks.
Kluk Ztopolovky is offline
post #2 of 19 Old 06-06-2019, 08:14 PM
jbolty
jbolty's Avatar
they are not hard to get off but will at least slow down a thief.
jbolty is offline
post #3 of 19 Old 06-06-2019, 08:31 PM
222Doc
222Doc's Avatar
could always just use red lock tight. sit back and watch the show.
222Doc is offline
post #4 of 19 Old 06-07-2019, 09:41 AM
Devil15
As someone who works on cars for a living, I can tell you everyone that uses wheel locks is a terrible human being. Double hate points if your one of the ones that hides the key and can't remember where they put it.
Sent from my SM-G892U using Tapatalk
Devil15 is offline
post #5 of 19 Old 06-07-2019, 11:09 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Locking lugnuts have always been useless. You just tap an impact socket onto them, and they spin right off.
underscore likes this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 19 Old 06-07-2019, 04:13 PM Thread Starter
Kluk Ztopolovky
red rock tight
thanks for the tip but now I just have to figure out what exactly "red rock tight" means , do I need set of big muscles for one of those special tights?
post #7 of 19 Old 06-07-2019, 09:18 PM
222Doc
222Doc's Avatar
red lock tight
use that and it will take heat to remove or just break off the studs......
222Doc is offline
post #8 of 19 Old 06-08-2019, 12:40 PM Thread Starter
Kluk Ztopolovky
yes but .....
red lock tight
this is certainly a very interesting product but I do not equip normally my car with a torch so I would be stuck on the road with a flat tire , how else could I remove my spare ? LOL
post #9 of 19 Old 06-08-2019, 01:23 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Most tire/rim thieves are not pros, locking lug nuts will defeat most of the less determined thieves. If you really want to be secure, I have seen somewhere you can buy a whole box of matching locking nuts for all four rims, so that each lug nut is a lock nut that would need to Macgyvered off, instead of just one per rim.
CJ7-Tim is offline
post #10 of 19 Old 06-09-2019, 08:40 AM Thread Starter
Kluk Ztopolovky
yes , that will do it
post #11 of 19 Old 06-09-2019, 11:59 AM
Rollin20z
Not a wheel/tire thief but have never found a wheel lock that wouldn't come off fairly easily without lock key. Have had a set of wheel lock removers for many years and can 99% of locks always come right off. As for the loctite method, if I were stealing your wheels do you think I would care about popping your studs off? Doesn't take much to do that either.
But if wheels locks make you feel more secure in thinking your wheels are safe from thieves that's good because that is why they are sold. Same as anything, if someone wants what you got bad enough they will get it.
True, unless you get one of those sets that the key ends up stripping/splitting on you rendering it useless and then you have possibly 20 lock you have to Macgyver off yourself, which could suck even more.
Rollin20z is offline
post #12 of 19 Old 06-09-2019, 06:18 PM
CJ7-Tim
CJ7-Tim's Avatar
A determined thief can steal just about anything that is locked, but even an idiot can steal unprotected tires/rims. My locking lug nuts have been off and on for tire rotations and winter/summer tire change overs for at least the last 10 years, and the key is just fine.
CJ7-Tim is offline
post #13 of 19 Old 06-11-2019, 04:31 PM
Rollin20z
Tim,
I didn't mean that in a rude way, I was just saying that some of those cheaper sets of 20 lug/locks can be a nightmare. I've known guys with them and never had a problem, but also seen some putting them on and not cranking down on them at all and the key stripped or split right out. My only advice is that if you are gonna get wheel locks don't skimp and get a nice quality set.
post #14 of 19 Old 06-11-2019, 04:56 PM Thread Starter
Kluk Ztopolovky
Originally Posted by Rollin20z View Post
Tim,
thanks Rollin , yes I think better quality is the way to go , thanks
post #15 of 19 Old 06-11-2019, 05:35 PM
Arjay
Most can be cracked eventually. Even the rotating collar ones. I guess if you put 4 or 5 of the rotating collar locks on EACH rim it would really slow the thieves down. They would need some real time to get all 4 rims.
Arjay is offline
