Adjust your tires with Up Down Air Inflation System + New Offer - JeepForum.com
post #1 of 1 Old 06-16-2021, 07:17 AM Thread Starter
CARiD
Vendor
CARiD's Avatar
While off-roading, you need to achieve the best traction between the tire surface and the ground, and letting some pressure out is the best way to do that. Without a reliable tire inflation kit for large tires at hand, it is more than difficult to succeed with this task. Thankfully, the guys over at Up Down Air have you covered with their innovative four-tire inflation system.
This handy kit allows you to inflate or deflate all four tires simultaneously, which makes managing tire air pressure quick and easy. Each system is designed specifically for your application with pre-cut hoses and quick-connect fittings to make the installation fast and simple.
Today we are here with Up Down Air Promotion! Make your purchase now and save up to 25% on select products! Hurry up! This offer expires on June 21, 2021. Prices are already reduced.
Up Down Air® - Air It Up™ Black GEN 2 Rear Engine Mount Tire Inflation System
Features:
  • Air It Up 4 Tire Inflation System can deflate, and automatically inflate or equalize 4 tires at the same time
  • ADS Controller features 2 inlet valves with permanent or portable air source
  • Heavy Duty Construction with DOT approved hoses and fittings
  • Designed to work with the EGOI 2 Air Compressor, ARB and Viair Compressors
  • Complete line of Air Compressor Bracket Kits Available for Under Engine, Under Seat, & Rear Cargo Area Mounting Solutions
  • One Year Warranty
  • Designed to help to get your job done right
  • Manufactured utilizing the highest quality materials
  • Built to provide exceptional levels of durability
Jeep Experts
Call Toll Free: 800.505.3274
CARiD is offline
