Lets Talk Docks - JeepForum.com
post #1 of 13 Old 08-22-2016, 07:22 PM Thread Starter
PM Thor
Custom User Title
PM Thor's Avatar
Location: Banging your head against a wall uses 150 calories an hour
Lets Talk Docks
Ok, so we bought a house that has a dock, it's a pontoon dock stabilized on poles on the corners....I have absolutely ZERO knowledge on how to winterize, no less maintain a dock.
Soooo, does anyone know anything about how to take in a dock off of a lake? We have to bring it in because the lake we are in is known for freezing at least a foot thick...
It's simply useless to argue on the interwebs. It's akin to arguing with a toddler. Doing so only makes you look silly and they always poop their pants.
PM Thor is offline
post #2 of 13 Old 08-23-2016, 07:42 AM
Kuntryboy816
Kuntryboy816's Avatar
How is it secured to the corner posts? Chain, rope, framed around the posts?
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #3 of 13 Old 08-23-2016, 07:55 AM
Shadownwpa
Shadownwpa's Avatar
Unhook it from the poles and bring it onshore. It shouldn't be too complicated.
https://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #4 of 13 Old 08-23-2016, 11:18 AM Thread Starter
PM Thor
Custom User Title
PM Thor's Avatar
It's framed around the posts, the posts stick out about 4-5 feet above the decking and the dock can float up and down around the posts. It's an L shape in 3 pieces, and the walk out deck, which is not even touching the water, then 2 10ish foot pieces secured to one another by cotter pins. These are wood frame docks, and appear to be pretty heavy. Here's a picture if it helps...best I have.
PM Thor is offline
post #5 of 13 Old 08-23-2016, 11:38 AM
Shadownwpa
Shadownwpa's Avatar
I wonder if maybe the prior owners used to pull the poles each winter then drag them up. Other option is a lift or crane to lift them off and put them back on... seems easier to pull the poles then hammer new in next spring.
post #6 of 13 Old 08-23-2016, 05:30 PM Thread Starter
PM Thor
Custom User Title
PM Thor's Avatar
Gotcha. Being the noob that I am about this, I even thought that they might have been on plates, but being hammered in sounds more realistic.
The former owner left a couple of comealongs labelled "dock" so I'm assuming he tied off to the big tree and just pulled them in that way, because man, they are pretty heavy.
PM Thor is offline
post #7 of 13 Old 08-23-2016, 06:16 PM
TimV
I wonder if the previous owner used the come along to just lift it up out of the water? As in hook them to the posts somehow, and lift the whole dock straight up, and leave it there.
Might be easiest to just try and track down a phone number for the previous owner, and find out what he did. If he's still local, maybe offer some compensation to come out and explain it better.
Why can't you just leave it out there? I understand the lake freezes, but it should freeze around the dock and not cause an issue in my opinion.
It's not an addiction. It's a way of life.
TimV is offline
post #8 of 13 Old 08-23-2016, 08:09 PM
Shadownwpa
Shadownwpa's Avatar
The problem comes when that foot thick ice shifts, cracks, or flows and the wood toothpicks holding it up follow suit. It would also be pretty hard on the pontoons I would think.
post #9 of 13 Old 08-24-2016, 01:24 AM Thread Starter
PM Thor
Custom User Title
PM Thor's Avatar
Yeah, there are pics of the dock on the shore. And Errrbody on the lake pulls their docks in, freezes so solid that a guy down the road takes his truck out, plows the lake and basically Zambonis the whole damn thing. The local kids have hockey tourneys out there. From what I've read, it's really bad for pontoons to be left in ice, basically ruins them.
The neighbor moved to Atlanta, wish they had been available to give me tips, but I will at least search for an email or something. To say it's been hectic doesn't do it justice.
PM Thor is offline
post #10 of 13 Old 08-24-2016, 11:58 AM
AftonJeeper
AftonJeeper's Avatar
Most floating docks around here are held in place by the poles. They have a screw tip on the end to bury them into the lake bottom. Look to see if they left behind a pipe wrench or a 2-3 foot long rod for removing the posts.
I'd use the come a long and some rope to pull each section individually on shore. Might need some plywood or 2x material to help them slide up on shore without causing too much damage to your yard.
AftonJeeper is offline
post #11 of 13 Old 08-26-2016, 04:56 AM
Ross
PM Thor, ask other people in the area what they do.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #12 of 13 Old 02-25-2017, 04:38 PM Thread Starter
PM Thor
Custom User Title
PM Thor's Avatar
Update.
Well, we talked to the former owner who said he has left the dock in for years and years with no problems. So that's what we did.....and this happened today...the dock is now beached on an island at least a quarter mile away....just ugh.
PM Thor is offline
post #13 of 13 Old 02-25-2017, 11:03 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
wow
***Chris***
chris87xj is offline
