Is your temp higher when towing? - JeepForum.com
 2Likes
  • 1 Post By jamief
  • 1 Post By Chirpz
post #1 of 13 Old 06-09-2019, 05:30 PM Thread Starter
rokrau
2008 WK
I noticed recently that when I tow my 21foot ski boat the temperature on the gauge goes to the first dash past half whereas it normally stays right on half or one dash below.
I don’t think I ever heard the fan coming on at full speed.
In the recent past I swapped the power steering pump that also drives the fan so I am wondering if there could have been some damage to the fan.
Anyone care to share their experiences? Was planning to tow for about 5 hours straight into 110F temp area in July.
—Roland
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #2 of 13 Old 06-09-2019, 07:00 PM
T1m
T1m's Avatar
2006 WK
I've only towed motorcycles and a car with the two-wheel u-haul thingy. They always felt like a feather behind me.
For the car, I towed it from New Orleans to Nashville. This was in my 3.7 Liberty with the towing package. it was easy - peasy.
I didn't notice higher temps when I towed.
Edited to add: I did use premium fuel for the tow, because I read it burns cooler.
T1m is offline
post #3 of 13 Old 06-10-2019, 10:16 AM
2005JGC
2005JGC's Avatar
2005 WK
How does your A/C work while you are stopped? I would expect it to kick up the fan speed to draw air across the condenser. If it is not, you likely have some issues.
You did use the special mopar fluid for the power steering fluid right?
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #4 of 13 Old 06-10-2019, 12:24 PM
T1m
T1m's Avatar
2006 WK
If you're asking me, I really didn't notice any difference in the behavior of vehicle. I did press the "tow" button that turns overdrive off as I was going through hilly highways to Nashville. The person behind me, who was driving the U-Haul, said she saw her car go in the air a couple of times - we had two-way radios.
The towing package also includes a transmission cooler, which I think is incorporated into the AC system. Like I said, I saw no difference in my vehicle's behavior.
T1m is offline
post #5 of 13 Old 06-10-2019, 12:26 PM
T1m
T1m's Avatar
2006 WK
Originally Posted by 2005JGC View Post
...You did use the special mopar fluid for the power steering fluid right?
I've never had to do anything with my power steering, yet.
T1m is offline
post #6 of 13 Old 06-10-2019, 01:56 PM
terrasmak
2007 WK
Mine is just above half when towing my open car trailer with a 3000 pound car. /50k miles ago it would stay on half.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #7 of 13 Old 06-10-2019, 07:58 PM
nvrdone1
2007 WK
I tow a 19' cuddy cabin boat that is 4200# on the trailer. my temp gauge normally runs right at the 1/2 mark when not towing. a laser thermometer pointed at the t'stat housing shows about 215 deg. when towing the gauge goes slightly above the 1/2 mark & the laser thermometer shows 240 deg. according to the dealer, this is well with in normal range. I did replace the radiator, water pump & hoses last year. its a 5.7 hemi
nvrdone1 is offline
post #8 of 13 Old 06-10-2019, 08:45 PM
Planetcat
2010 WK
My hemi wk and my dodge cummins 2500 pickup truck both exceed the normal temp range when towing, but mostly in stop-go traffic and up the mountains. Even if the weather is in the 80ís it happens. Mostly towing my 4500 lb boat. I would be moderately concerned towing a 21í ski boat for 5 hrs in 110* temps, but less concerned if its all flat roads. Like nvrdone said, 240* would be hot but not out of the question. That would be my max before i pulled over though.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #9 of 13 Old 06-10-2019, 11:18 PM
jamief
when empty I'm just below half. Towing a 5000lb camper it goes to one mark above half. This is with the 3.0L CRD
2005JGC likes this.
jamief is offline
post #10 of 13 Old 06-10-2019, 11:32 PM
Chirpz
Chirpz's Avatar
2007 WK
No... only when going up a steep grade. My trailer is only 18' and my loaded gross weight is around 9,800...it varies a little.
2005JGC likes this.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #11 of 13 Old 06-11-2019, 01:35 AM Thread Starter
rokrau
2008 WK
My A/C does work but is less cold while stopped for sure. The fan speed is high but I can not tell if it is maxed. I believe there were some posts here on the forum on how to test.
Yes, I did! And I actually check the level of the fluid regularly now. Changing the pump on the CRD is a royal pita.
rokrau is offline
post #12 of 13 Old 06-11-2019, 12:10 PM
2005JGC
2005JGC's Avatar
2005 WK
Sounds like its pretty normal for the 3.0 guys.
I know my temps will creep up just lugging birtha up a mountain pass trying to keep up with the rest of the party doing 65-70. I do not recall it ever working up past the middle line though (4.7l gas here, also not towing anything except poor gearing for the tires and the heavy jeep full of camping stuff).
2005JGC is offline
post #13 of 13 Old 06-12-2019, 11:30 AM
Capital AL
2010 WK
I occasionally tow my ATV with a few other things. The trailer is about 2000 pounds. I have the 3.7 engine and temperature always stays the same, 1 mark under half way, regardless of city or highway driving.
Capital AL is offline
