WK Transmission cooler and air conditioning condenser - JeepForum.com
post #1 of 6 Old 01-23-2017, 04:17 PM Thread Starter
suzieque
2008 WK
my understanding is that the OEM WK automatic transmission cooler and air conditioning condenser are in the same physical unit.
in looking at pictures of the OEM WK automatic transmission cooler and air conditioning condenser, I see 4 connectors. 2 connectors at the top right (when facing the vehicle) and 2 connectors in the middle right.
I believe the top 2 connectors on the right are the transmission lines, can anyone confirm that for me?
Also, if the top 2 connectors on the right are the transmission lines, can anyone confirm that the transmission fluid only circulates through about the top 1/3 of the physical cooler?
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #2 of 6 Old 01-23-2017, 05:29 PM
Nejeep
2019 WK
The top 2 connectors are for the trans cooling lines. I would say the area is less than 1/3 of the total. It appears to me its just 2 tubes (over and back), but seems to work well as the ambient air going thru the WK cooler is always at a lower temp than the engine coolant (180F+) used in many other vehicles.
19 Limited 4x4 3.6 White/Tan new daily driver
06 Laredo for 11 years
97 Laredo for 14 years
Nejeep is offline
post #3 of 6 Old 01-23-2017, 05:43 PM Thread Starter
suzieque
2008 WK
thanks for the reply!
in my towing experience in the summer, the single physical unit gets very hot with the air conditioning running and towing my travel trailer, transmission well over 200 degrees as measured by the aftermarket guage, I had to shut down my air conditioning to bring my transmission back down to 200. Well over 200 is to hot for the safety of my tranmission - in my opinion.
so, I'm going to do an experiment and post my results to the team.
my experiment is to get another physical OEM unit, chop the top half off and put my tranny lines to this shorter unit just in front of the unmodded stock unit thereby putting the tranny cooling and air conditioning in 2 separate physical units. That way, the air conditioning will not affect my transmission.
if there's not enough free play in the tranny lines, I will cut the unit in place so that they are separate.
suzieque is offline
post #4 of 6 Old 01-24-2017, 06:08 AM
Nejeep
2019 WK
It seems to me it would be easier to purchase an aftermarket trans cooler and mount it, than to modify a factory unit (maybe less costly too). However if you have access to a used low cost condenser and enjoy reworking things (like I do) give it a go .
Nejeep is offline
post #5 of 6 Old 01-25-2017, 05:25 PM Thread Starter
suzieque
2008 WK
I will post back pics when I do it and my tranny temp while towing.
suzieque is offline
post #6 of 6 Old 07-23-2019, 07:19 AM
Canadianjeepers
Old thread, I know...but looking to see if you ended up adding a it, and how towing went?
Canadianjeepers is offline
