WK Rear sway bar links... - JeepForum.com
post #1 of 7 Old 09-10-2020, 02:13 PM Thread Starter
2007laredowk
2006 WK
When installing the srt rear sway bar on a non-srt wk, do I need to buy the srt links too? I read somewhere they weren't necessary, the non-srt ones should work. I can visually see they are different and need to replace the originals anyways due to wear so which ones should I get?
2007laredowk is offline
post #2 of 7 Old 09-10-2020, 02:29 PM
Kman09JGC
Kman09JGC's Avatar
2016 WK
No the srt one are shorter. Just go with moog problem solver ones. I went Bwoody on my 09 never had any issues just keep them greased.
Sent from my iPhone using Tapatalk
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline
post #3 of 7 Old 09-10-2020, 05:12 PM
nvrdone1
2007 WK
i used the stock ones that were on the jeep from new when i swapped for an srt bar. works fine.
nvrdone1 is offline
post #4 of 7 Old 09-11-2020, 06:42 AM
yzjwk
yzjwk's Avatar
2005 WK
I would say that depends if you are lowering the suspension to match an SRT or not... If you are, then use the shorter SRT links, but if you are just changing to the stiffer bar and staying at normal height, then use the regular / longer links .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #5 of 7 Old 09-11-2020, 02:59 PM Thread Starter
2007laredowk
2006 WK
Originally Posted by Kman09JGC View Post
moog, Bwoody
I'm going mopar on these, just matter of regular wk or srt ones. Keeping it OEM simple since there's no point in installing an aftermarket upgrade when I can upgrade other suspension parts too that won't be replaced for now, because the Bwoody suggestion.
Originally Posted by nvrdone1 View Post
i used the stock ones, works fine
That's what I read, just wanted to confirm.
I already have the srt springs ready to be installed.
post #6 of 7 Old 09-11-2020, 07:16 PM
yzjwk
yzjwk's Avatar
2005 WK
If youíre going to install the SRT springs with the sway bar then you should use the SRT links .
Donít forget to get a good alignment after itís all done too
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #7 of 7 Old 09-13-2020, 01:55 AM Thread Starter
2007laredowk
2006 WK
Will do. Thanks for the input from everyone.
