WK CRD air box removal, prior to alternator replacement - JeepForum.com
post #1 of 5 Old 07-20-2016, 03:15 PM Thread Starter
oilverland
2008 WK
Hi - Instructions I find for alternator replacement, such as in
https://www.jeepforum.com/forum/f67/3...ation-1395553/
say to remove the air box (the whole thing). It is somehow fastened to a rubber mount at the bottom. Do I yank the box out, or turn that mount from the bottom? Is there a bolt there? (I don't see so well close up so I can't tell if it's a bolt or what.)
Thanks in advance,
Tommy
SOLD, July 2018 - 2008 Overland Diesel QDII, Thanks for the 6 1/2 years of help!
oilverland is offline
post #2 of 5 Old 07-20-2016, 07:13 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Yes, there's a bolt at the back of the box, you gotta look for it iirc it's somewhat hidden. Access from the top.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #3 of 5 Old 07-20-2016, 11:32 PM
ggrassmid
2008 WK
1 bolt along the wheel well tub. The rubber mount in the bottom just pulls out or pushes in
ggrassmid is offline
post #4 of 5 Old 07-22-2016, 09:21 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
While you're at it, please send me the length and thread of that bolt. (The mechanic 'misplaced' mine.)
89 GW w/plow
wookiee is offline
post #5 of 5 Old 08-07-2016, 10:24 AM Thread Starter
oilverland
2008 WK
I looked again, finally, no evidence of any bolt. There is a rubber mount on the fender side of the box, held in place by a rubber mount. It sticks through with a conical taper and then a slot at the bottom of the cone. Does not come off trying easily!
So I have an 08 and the prior post an 07 - did it change? Or did the dealer cut off that cone leaving what might look like a bolt hole?
It took me a while to get motivated to get back to this because the noise that I thot was the alternator went away within a day. There was paving going onto the local country road and I may have picked up a bit of sticky gravel that eventually came out.
air box , alternator , crd , wk
