WK Cluster**** - JeepForum.com
post #1 of 8 Old 08-21-2019, 10:55 AM Thread Starter
hem1
hem1's Avatar
WK Cluster Issues
Hi Jeep Forum!
I'm a brand-spanking new WK owner - 2010 5.7L with 130k miles. I have never had a Chrysler product before, and so far I am impressed. There's a few odds and ends I want to sort out and was hoping to gain some collective knowledge.
My speedo stopped working - needle points to the floor. The coolant temp is also hit and miss. Sometimes it works, sometimes it doesn't.
My shop said I have to replace the cluster (or get a guy to fix it, which will cost more). I found a replacement cluster for a reasonable price, but it was from a 6-cylinder WK from 2009. Considering I have a totally different motor, can I still use that cluster?
Thank you so much in advance for your help!
hem1 is offline
post #2 of 8 Old 08-21-2019, 08:32 PM
badgerwithhands
2007 WK
What are you doing with your bad one? I'll take it. I'm experimenting with my gauge cluster and want an 08-10 to play with.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #3 of 8 Old 08-26-2019, 12:38 AM Thread Starter
hem1
hem1's Avatar
Is your cluster having any issues? Is your LED display green or white? I don't mind parting with my current one, but I haven't yet found a working cluster that will function 100% =)
hem1 is offline
post #4 of 8 Old 08-26-2019, 01:29 PM
badgerwithhands
2007 WK
No mine is fine, it's an '07 so its green. I wanted to see about swapping white in
post #5 of 8 Old 08-26-2019, 03:08 PM Thread Starter
hem1
hem1's Avatar
Does your engine size matter? 6 or 8 cyl? Or it will work regardless?
hem1 is offline
post #6 of 8 Old 08-27-2019, 08:09 AM
badgerwithhands
2007 WK
Mine is a diesel. I don't anticipate it being an issue, could be wrong. But I would butcher it if it doesn't plug and play. I'm getting the idea you want to swap with me, I'm not for that. I know mine works. But if you're trying to see if a junkyard cluster works, that's an idea.
post #7 of 8 Old 08-27-2019, 10:43 PM
underscore
2007 WK
From my understanding the cluster and the ECU both store the odometer reading, and if they don't match it will throw a code. I'm assuming it's not too difficult to fix but it's something to watch for.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #8 of 8 Old 08-28-2019, 02:24 AM Thread Starter
hem1
hem1's Avatar
Yikes! Thank you for that bit of wisdom. So I guess by saving mine, I avoid more problems.
I took apart the center console today on a hunch, thinking the ground wire by the shifter was messed up. I was totally wrong. I also looked through the engine bay at any ground wire I can easily get my hands on, and the only one that looked a little worn was the flat ground strap that is designed not to interfere with the radio signal (the one onto the firewall on passenger side).
Grounds are fine!! It must be the cluster itself. I literally drove off the lot with the truck right in time for this issue to come up.
hem1 is offline
