WK 4.7 replacement engine - JeepForum.com
post #1 of 5 Old 10-28-2018, 02:35 PM Thread Starter
t.mcginley.jr
t.mcginley.jr's Avatar
Hi all,
I'm looking at buying this 05 WK with 88k miles on it for a whopping $400. It has the 4.7 v8 and it's blown for whatever reason.
Good used engines seem pretty pricey, in the $2k range around me (NJ). Can I swap in a 4.7 from a WJ? or at least use the 4.7 shortblock and put the newer 4.7 accessories, heads, intake, etc. on?
Anything else to look out for? I'm an XJ guy so I know my way around Jeeps just haven't ever bought a grand cherokee.
Thanks!
t.mcginley.jr is offline
post #2 of 5 Old 10-28-2018, 02:45 PM
RCS1300
2005 WK
If there is significant rust underneath, pass on it.
I am the original owner of a O5 4.7L that now has 90,000 miles. If the engine is blown there is an excellent chance that other significant expenses will follow once a reman engine is installed. Have to figure the owner did little if any maintenance. Set aside an additional $3,000 minimum new parts budget for this 13 year old vehicle plus the cost of the new (Promar) reman engine, shipping, and installation for $4,300 ($2,800 + $300 + $1,200).
What is blue book value now, about $6,000?
(wheel bearings, struts, shocks, tie rod ends, brakes, maybe catalytic converters, radiator, water pump, hoses, fuel pump, tires, battery, fluids (tranny, radiator, differentials, transfer case, power steering, and brakes), etc)
RCS1300 is offline
post #3 of 5 Old 10-28-2018, 02:49 PM Thread Starter
t.mcginley.jr
Originally Posted by RCS1300 View Post
I am the original owner of a O5 4.7L that now has 90,000 miles. If the engine is blown there is an excellent chance that other significant expenses will follow once a reman engine is installed. Have to figure the owner did little if any maintenance. Set aside an additional $3,000 minimum plus the cost of the new engine and installation.
Thanks for the quick reply!
I would be doing all the work/labor on the Jeep, but you're right I'm sure very little maintenance has been done if the engine is already shot. If I buy it I would try to get a good used engine for as cheap and possible and freshen it up.
Blue book right now is between $4-6k depending on condition.
post #4 of 5 Old 10-28-2018, 07:35 PM
2005JGC
2005JGC's Avatar
2005 WK
The wk and wj 4.7l engines are different. Different tone rings. The PCM wont know how to interpret the engine speed. The cam gear can be swapped but the crank tone wheel is built into the crankshaft. Whatever engine you get, pop the valve cover off and verify the cam tone wheel is the same as what ya got.
2005JGC is offline
post #5 of 5 Old 10-28-2018, 07:46 PM Thread Starter
t.mcginley.jr
Good point, I think the reluctor (tone) rings can be unbolted though. As long as the holes line up I could swap the one from mine onto the crank from the older engine.
It won't let me post pics yet, but I think the older WJ cranks have a 16-tooth tone ring and newer WK has a 32 tooth one. 3 bolts hold it onto the crank itself. Obviously I would have to tear the engine down to make it work. I bet the cam tone wheels can swap too.
engine failure , grand cherokee
