Will JK Rubicon wheels clear my calipers? - JeepForum.com
post #1 of 8 Old 05-15-2020, 03:28 PM Thread Starter
nomercy346
2008 WK
Can you fit JK Rubicon wheels without running spacers or is it the same deal as with JK Moabs and they'll hit the caliper?
Also: will 265-70-17s on JK wheels clear my UCA bolt without spacers?
Thanks!
08 WK Limited CRD
14 RAM 1500 Hemi, CCSB
96 ZJ Limited 5.2 - sold
nomercy346 is offline
post #2 of 8 Old 05-16-2020, 10:00 AM
nvrdone1
2007 WK
ive got rubi's on my 07 GC and the fronts did rub the caliper brackets. you have 4 choices:
1) grind the caliper mounting bracket until it clears the wheel.
2) use spacers / adapters that will move the wheel out about 2".
3) find a different set of wheels.
4) do what I did - use a 1/4" spacer that goes over the studs between the rotor and the wheel. ive had them on for about 3 years and over 60000 miles. no problems yet.
nvrdone1 is offline
post #3 of 8 Old 05-19-2020, 09:40 AM
Grinmaul
2008 WK
Thanks!
I had 1.5 inch spacers, i did not like the look and felt less safe if that makes any sense. i know people are using them and have millions of miles and do 20 foot jumps or something with them and no problems. it was an unnecessary expense for me.
Ended up grinding down the caliper bracket a bit and taking the hex part of the upper ball joint bolt off with a cutting wheel, much happier.
2 2008.5 WK CRD's, 2005 WK Limited 5.7
Grinmaul is offline
post #4 of 8 Old 09-15-2020, 07:53 AM
Jambalam
Jambalam's Avatar
2007 WK
Can we see a photo of the upper ball joint bolt? Also does that make removing it that much harder? I can barely fit my finger between mine and the tire.
2007 Grand Cherokee Limited CRD.
2006 Grand Cherokee Larado 3.7 V6.
Denver,CO
Jambalam is offline
post #5 of 8 Old 09-15-2020, 08:03 AM
Jambalam
Jambalam's Avatar
2007 WK
Denver,CO
Jambalam is offline
post #6 of 8 Old 09-15-2020, 08:04 AM
222Doc
222Doc's Avatar
20 foot jumps????? no damage LOL........
222Doc is offline
post #7 of 8 Old 09-15-2020, 08:22 AM
offroading.net
offroading.net's Avatar
2007 WK
Just fitted JK alloys, needed a 30mm spacer to clear the caliper, the actual interference isn't that much, maybe a couple of mm, but I am not a fan of taking a grinder to my brakes
Steve Wright
'07 Grand Cherokee Overland CRD
'20 Renegade S, Wifey Wagon
Previous Jeeps- 8 XJs, 3 KJs, 3 WJs, 2 TJ's, an MJ & a Renegade
offroading.net is offline
post #8 of 8 Old 09-17-2020, 02:04 AM Thread Starter
nomercy346
2008 WK
Running JK moabs now with a 1 spacer and 265-70-17 KO2s. Clears everything.
Sent from my iPhone using Tapatalk
08 WK Limited CRD
