What years will fit? - JeepForum.com
 2Likes
post #1 of 23 Old 03-29-2020, 12:33 PM Thread Starter
WallyDog1
WallyDog1's Avatar
Hi all I'm new to the WK forums been spending my time in the Wrangler forums. I have a 91 YJ and just added a 2008 Grand Cherokee Limited to the fleet. I bought it for $300.00 and needless to say the Cherokee needs some help. The first issue is the engine. The guy drove it till it stopped. No water or oil in it...So I'm after a used engine for starters. Can you guys tell me what years will fit and from what I've read about swaps so far the chassis # has something to do with choosing the right one.
ALSO it looks like a bear of a job?
Thanks!!
From the Smoky Mountains of Western North Carolina
WallyDog1 is offline
post #2 of 23 Old 03-29-2020, 01:37 PM
Alex_
Well in 2008 they upgraded the engine as you can see here; It is a pretty big job to remove the engine and put in a new one, almost everything on the engine bay has to come out, also disconnect the engine from the transmission, have a engine jack to remove the old engine put the new one, unless you got the tools and some help I would not recommend it doing it yourself.
In here you can search all the salvage yards in USA as far as I understand its a national salvage yard sale, look for an engine there thats close to you or that they can ship to you.
The other way is to get a reman engine it is pricey tho..
Most importantly are you sure the engine is shot? did you do a test on the jeep with a scanner on it or took it someone to have it check?; maybe you don't need a new engine but replace some components as long as the cylinder heads and the block are not cracked.
Alex_ is offline
post #3 of 23 Old 03-29-2020, 01:52 PM
underscore
2007 WK
Most importantly, what engine does it have now?
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #4 of 23 Old 03-29-2020, 06:12 PM Thread Starter
WallyDog1
WallyDog1's Avatar
My back ground is mechanical so doing an engine swap is not an issue and I do have the engine crane and the tools...Impact tools and compressed air. Just did the engine in my YJ over the winter.
I'd say for sure the engine is toast! A 2 ft breaker bar wont budge it and like I said there is no oil or water in the radiator or crankcase. mixed or otherwise.
post #5 of 23 Old 03-29-2020, 06:13 PM Thread Starter
WallyDog1
WallyDog1's Avatar
The 4.7 V8 Gen2 If it was installed in all 08's. This is the chassis # 1J8HR58NX8C213174.
post #6 of 23 Old 03-29-2020, 06:40 PM
Alex_
Well that's perfect then if you have the tools and knowledge to do it yourself can save a lot of money; I recommend you grab the factory service manual for the jeep.
As you said the engine is empty but have you tried to see with a new battery if it will crank at all, most likely is seize but its worth a shot. Did you put a scanner on it, if so what codes did you get? I think first thing you should do is get the codes to see if the trans or anything else besides the engine is damaged
Alex_ is offline
post #7 of 23 Old 03-29-2020, 06:50 PM
caulk04
2008 WK
08 was an update year for the 4.7.
You should be good with any dual plug (08+) 4.7. the 4.7 died off only a couple years after this update.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #8 of 23 Old 03-29-2020, 07:42 PM Thread Starter
WallyDog1
WallyDog1's Avatar
The previous owner put a new battery and a starter in it. A so called mechanic friend told him the starter was bad. They put a new radiator in it too. All bonus parts for me! I figure with no oil or water and a 2 ft breaker bar, it's a stuck deal. I'm looking for a used engine. On the financial side the Jeep is not worth the price of a new reman.
post #9 of 23 Old 03-29-2020, 07:48 PM Thread Starter
WallyDog1
WallyDog1's Avatar
Dodge trucks included?
post #10 of 23 Old 03-29-2020, 07:51 PM
Alex_
thats great on the bonus parts; My recommendation to pull codes stands and over at the link on my first comment you can search for the engine on salvage yards, Hope it helps you.
Alex_ is offline
post #11 of 23 Old 03-30-2020, 05:58 AM
caulk04
2008 WK
Yes, 08 was the first year and they quit using it soon after. I think when the 3.6 started in the trucks they ended the 4.7.
caulk04 is offline
post #12 of 23 Old 03-30-2020, 06:57 AM
yzjwk
yzjwk's Avatar
2005 WK
according to your VIN, that jeep has the California emissions package. Depending on your states inspection / swap rules you may have to find a 4.7 with the same.
I don’t know what the difference is but Just throwing that out there for you.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #13 of 23 Old 03-30-2020, 10:46 AM Thread Starter
WallyDog1
WallyDog1's Avatar
I found the build sheet on one of the links you sent. I came up with 4.7 Gen II MPI and in a different spot found EVE. ( pull codes stands?)
I was also wondering if It's a possibility to swap in a 5.7? Of coarse without getting into a major mess trying to make it work. It would probably bolt in but what about the electrics.
post #14 of 23 Old 03-30-2020, 10:50 AM Thread Starter
WallyDog1
WallyDog1's Avatar
I donít know what the difference is but Just throwing that out there for you.
Our county in NC does not have an emissions inspection. But I still like to conform. I'd be after the same.
post #15 of 23 Old 03-30-2020, 06:05 PM
Alex_
Yeah definitely pull the codes with an obd scanner to see if any other failure is on the vehicle, because lets say you get a used engine but the transmission is shot or there are other electrical issues.
I wont lie to you I don't know about engine swaps but from what I been seeing you gonna have to get the pcm re-programmed for the new engine if not a new pcm and also you need to see if the 5.7 used the same trans as the 4.7, Could be possible I suggest you research about it.
Also Heres All the info on the jeep
Alex_ is offline
