What would cause this at startup!? - Page 9 - JeepForum.com
post #121 of 125 Old 03-16-2016, 05:49 AM
Bmoor2323
Just wanted to give everyone an update. Been a week now and still no problems ! Multiple times where it wouldn't start in the past it currently starts. Good luck to everyone. Probably one of the most annoying problems I've ever had with a truck
Bmoor2323 is offline
post #122 of 125 Old 04-03-2016, 06:26 PM Thread Starter
yem514
2007 WK
Hey guys !!!!!! Guess what??
I just replaced my fuel pump and drove about 150 km in the city for 2 days. Lots of stop and restarts.
I am happy to say that it seems to be fixed!!!!!!!!!! Not once did it hesitate.
I will give an update in 5 days I will then change the first post and title if possible!
Although everyone here said to replace the fuel pump I did not do so because 4-5 different mechanics ( 2 from independent, friend's,2 dealers) told me it's not the problem. After replacing so many parts and spending so much money on diagnostic there was nothing left to replace but the fuel pump!!! So I also did because 2 other guys here said it was successful!
I hope to give good news in 5 days!
BTW Mopar fuel pump from Rock auto 265$ CAD to my door. 1 1\2 hours for labor
yem514 is offline
post #123 of 125 Old 04-07-2016, 01:01 PM Thread Starter
yem514
2007 WK
Case solved: FUEL PUMP !!!
I said that I would update in 5 days but i have put about 350km since the fix and not once did it hesitate. Starts real smooth. I did the memory reset thing (disconnecting battery)after the fuel pump replacement. Wooooooo, feels great
yem514 is offline
post #124 of 125 Old 04-07-2016, 06:59 PM
Bmoor2323
Nice !! I probably put close to 1,000 miles on since and it's been perfect. It use to hesitate for a split second for the first week but now it's like I never had the problem. All good thanks everyone
post #125 of 125 Old 12-12-2019, 10:15 AM
slimnasty
Struggled with this issues for months. My Jeep ran great once running. Only issue ever was restarting after 15-30min soak. I was able to verify it is likely the fuel pump with a pressure tester in the rail. When the issue would occur the pressure would fluctuate around 40 psi and up to 50 and move all over. Then when it would manage to start the pressure would be at spec but wiggling 5psi or so.
It would start with starter fluid and would hold pressure after shutdown for 5min.
Pulled the trigger and replaced the fuel pump ($730). 3 hrs labor to r&r and clean fuel tank plus $300 for the pump (carter from NAPA).
No issues since. Hope this helps someone searching for answers.
slimnasty is offline
fuel pump
