What are these parts called? - JeepForum.com
post #1 of 13 Old 11-10-2010, 10:08 PM Thread Starter
AntiPlanar
2005 WK
Is the part circled in green the front lower control arm? If not what is it?
And the bolt circled in red, it sits inside a rubber sleeve or bushing of some sort. If I need to replace these rubber bushings, what are those called?
Long story boring, I attempted to install my 2" Daystar spacer lift and because I could not remove the bolt circled in red, the lift was not installed. I'll have to try again Friday.
Thanks for the help.
AntiPlanar is offline
post #2 of 13 Old 11-10-2010, 10:25 PM
PlatinumNiner
Lower a arm and that bolt is for your strut
PlatinumNiner is offline
post #3 of 13 Old 11-10-2010, 10:36 PM Thread Starter
AntiPlanar
2005 WK
Yes I realize the bolt is for the strut but does that bushing around the bolt have a specific name? There's a good chance I'm going to have to take a blow torch to the bolt to get it out, which will destroy the bushing. I'd like to find replacements before I fug it up.
post #4 of 13 Old 11-10-2010, 10:40 PM
djeep05
djeep05's Avatar
2005 WK
I just install a RC 2" lift. I had trouble with mine as well. PB Blaster and alot of twisting and pushing in and out and it came out without damaging anything.
djeep05 is offline
post #5 of 13 Old 11-11-2010, 04:58 AM
AJeepZJ
AJeepZJ's Avatar
2006 WK
the green circled area is called the Lower control arm. The red circled area is the strut fork's bolt location to the LCA. The bolts location next to the predescribed is one of the swaybar linkages to the LCA. why's yours so CLEAN underneath, lol?
I'm not entirely sure why you need a blowtorch to get it out, It will come out using a lil manpower. I was able to loosen it enough untill it no longer screws and just tapped it out with a hammer. I disassembled everything you have circled there to make it easier to install my lift. Well, I disassembled the other swaybar link location. But I did take that dang strut fork out.
All Gear, No Skill.
AJeepZJ is offline
post #6 of 13 Old 11-11-2010, 06:04 AM Thread Starter
AntiPlanar
2005 WK
This isn't my pic. I used it for reference purposes. I wish my undercarriage was that clean.
post #7 of 13 Old 11-11-2010, 10:10 AM
CraigWK
CraigWK's Avatar
2005 WK
FYI after 2 days of trying everything from MAT torches to wrenches and everything inbetween, I eventually cut the damned bolt out and replaced it with new grade 8 bolts that I was able to pick up at ACE hardware. They were completely fused to the fork so after they were cut, an hour in an acid bath finaly broke the pieces free out of the fork.
I have not heard of anyone needing to replace the bushings but you can order any and all of these parts through a mopar dealer. You can google image search to even find diagrams that give you the part numbers if you want to order specific pieces.
Sold...-=2005 WK Grand Cherokee 4.7L rocky mountain edition=-
OME HD lift | Saguaro front bumper | JK 17" wheels with 32" BFG KM Mud tires | 4xGuard skid plates (belly, rear) | D-rings | Husky Liners throughout | SuperChip mod | Warn M8000
CraigWK is offline
post #8 of 13 Old 11-11-2010, 03:52 PM
AJeepZJ
AJeepZJ's Avatar
2006 WK
oh! lmao!
All Gear, No Skill.
AJeepZJ is offline
post #9 of 13 Old 11-12-2010, 08:51 AM
jstand22
The one in red is called a strut clevis bolt, so you'd be looking for the strut clevis bushing. More specifically the strut clevis bushing that goes through the lower control arm.
The big black arm you circled is your lower control arm (or A-arm).
jstand22 is offline
post #10 of 13 Old 11-12-2010, 03:25 PM
fitbmxseries1
1987 YJ Wrangler
check out wkjeeps.com theres a PDF that will have exploded veiws with part numbers! for some reason the site is down. hopfully it will be back soon!
2005 Jeep grand Cherokee WK 2" rough country lift 1.25 wheel spacers 255/75/17
Blue WK club #5
1987 Jeep Wrangler YJ, random leafspring budget lift ith 33s on 16s and V8 swap.
1999 Jeep Cherokee XJ --SOLD.
fitbmxseries1 is offline
post #11 of 13 Old 11-12-2010, 07:32 PM
V6WK
2005 WK
FYI, Jeep does not sell that bushing separately! And to my knowledge there are no aftermarket companies that make a replacement. I know what your thinking.... "ya right, whos this guy" but I went through the issue of that clevis bolt not coming out when I did my lift. Long and the short of it is do what you can to get the bolt out but dont F up that bushing unless you have a spare LCA around.
05 WK, 3.7L, 2" Rough Country, 245/75/17 Hankook RF-10, Hella 500's behind the grill
V6WK is offline
post #12 of 13 Old 11-12-2010, 09:49 PM
fitbmxseries1
1987 YJ Wrangler
you seem to be correct! there is no part number for the bushing just the lower control arm that includes the bushing! To get mine off i bent the tab over and stuck an impact on the bolt head then with the nut loosened i had some one hit it with a hammer on the nut side, took about 10 mins of that then it slowly started moving. about an hour later i had the bolt out. broke the tab though and had to weld it. then put anti seize on it when i put it back.
Blue WK club #5
post #13 of 13 Old 11-14-2010, 06:13 AM
V6WK
2005 WK
Great, glad that you were able to get it.
V6WK is offline
What is this called? And where can I get it? pleXX ZJ Grand Cherokee Forum 16 06-04-2010 06:11 PM
Can anyone tell me what this part is called? rob miller ZJ Grand Cherokee Forum 10 12-31-2007 03:13 PM
What is it called? gtowngirl ZJ Grand Cherokee Forum 4 09-25-2007 06:52 PM
How is this called? Grdaemon ZJ Grand Cherokee Forum 27 07-20-2007 09:36 PM
Whats this called again (pic) sparco565 ZJ Grand Cherokee Forum 3 08-03-2005 09:07 AM
