What's the mileage on your CRD? - JeepForum.com
post #1 of 17 Old 01-11-2019, 02:49 PM Thread Starter
Curlybandit
My '08 JGC Overland CRD is a work vehicle. I do around 50,000km (31,000 miles) a year. I could try selling it or trading it in but I'm not ready for that yet. There's still too much I love about it that keeps me from letting it go, in spite of the issues associated with a vehicle (ANY vehicle) with high mileage. It's really more of a love/hate relationship - more love than hate.
I recently just passed 340,000km (~211,000 miles). Original engine. Original transmission.
Edited to include the most recent services (as others have done):
- replaced fuel tank (last month)
- replaced turbo actuator (this weekend)
What's your CRD mileage?
2008 Jeep Grand Cherokee Overland QDII
3.0L V6 Turbo Diesel
Green Diesel Engineering Eco Tune
Curlybandit is offline
post #2 of 17 Old 01-12-2019, 07:47 PM
07JeepGRC/CRD
2007 WK
Hi, I've got 169,000 miles on my 2007. Bought it with 128k. Replaced the alternator at 160k, and the turbo actuator at 165k. Runs really good with no problems.
07JeepGRC/CRD is offline
post #3 of 17 Old 01-12-2019, 08:25 PM
Sosruko
Sosruko's Avatar
2007 WK
I'm at 158,000 miles on my 2007. Bought it at 142,000 miles in March... I've had a few no-start issues, but I think those are now ironed out. I've replaced Crank/Cam sensors, timing chain, and discovered a broken lock on a 48-pin connector (which I believe was the main issue the entire time).
I also replaced the turbo actuator with the G-001 part from Amazon a few months ago.
2007 WK CRD Limited 4X4, QDII, GDE EcoTune, 245/70R17 on stock rims, OEM Tow Hitch
Sosruko is offline
post #4 of 17 Old 01-13-2019, 01:19 AM
badgerwithhands
2007 WK
125k miles, '07. Oil cooler seals (duh), turbo actuator, suspension stuff. Runs awesomely
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #5 of 17 Old 01-13-2019, 01:28 AM
terrasmak
2007 WK
185k miles, need to do the oil cooler soon. Also need to service the trans
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #6 of 17 Old 01-13-2019, 08:44 AM Thread Starter
Curlybandit
I see that others have included recent service.
Thanks for sharing!!
I edited my original post to include the most recent service.
Cheers!
post #7 of 17 Old 01-15-2019, 08:11 PM
Tango.
180 k
just maintenance and add-on parts
only part that went out was the swirl motor (at 39k)
maintenance includes those copper O-rings on the injectors.
Life is hard-John Wayne
Tango. is offline
post #8 of 17 Old 01-18-2019, 10:13 PM
ZJPunk98
ZJPunk98's Avatar
2007 WK
79,000 miles. all original right now. just basic maintenance. No major parts to be repaired or replaced yet.
Erik
98ZJ sold, 02WJ sold, 07 WK CRD
ZJPunk98 is offline
post #9 of 17 Old 05-31-2019, 11:19 AM
RSA_Limited
2005 WK
265,000km (165k-mi) - bought in 2011 with 120,000km (75k-mi)
Engine oil changes every 15,000km
Diesel fuel filter changes every 20,000km
Surpentine belt replaced @ 160,000km
Coolant replaced @ 235,000km
6x injectors replaced @ 255,000km
Also lost engine temperature sensor, swirl motor, 1x front shock absorber, failed AC condensor, 6x glow plugs, 2x rear discs
Remains an awesome vehicle
Suspect timing chain wear currently - not sure what life is expected from the chain, chain guides and tensioner - anyone who has info on this or done a replacement?
RSA_Limited is offline
post #10 of 17 Old 05-31-2019, 01:26 PM
ggrassmid
2008 WK
234,000 miles
376,500 kilometer
ggrassmid is offline
post #11 of 17 Old 05-31-2019, 05:43 PM
rokrau
2008 WK
Originally Posted by Sosruko View Post
I've ... discovered a broken lock on a 48-pin connector (which I believe was the main issue the entire time).
What did you do about that? ZipTie?
—Roland
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #12 of 17 Old 05-31-2019, 06:59 PM
SteveROntario
240,000 km on my 2008.5. Suspension, CV shafts, conductor plate, accessory pullies/belt, front diff, and a few glow plugs so far. It will be decision time when the oil cooler has problems. If it happens during the winter I'll be in trouble and I don't want to preemptively give up 20 hours of my summer either.
I drive about the same amount as you.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #13 of 17 Old 05-31-2019, 08:19 PM
Chirpz
Chirpz's Avatar
2007 WK
I purchased 07 in 08 when it had only 11,000 miles on it. Now it has 149,000.
Oil Pressure Sensor (13,000)
Crank Position Sensor (11,500)
Shocks all around (used Bilsteins) - recently
Rear Brakes - Last year
Alternator - (2x - on my third one)
Swirl Motor (install GDE tune) - (56,000 I think)
Turbo Actuator (96,000 I think)
Complete dealer lube at (100,000) (Won't do that again)
Oil, Filters, as required
Air Ventilation Gear replaced
NO N23 or followup....I'm original
The amazing thing to me is the front brakes.... I'm still using the original pads and rotors, and they are still good...yes they work.... I've logged over 30,000 towing.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #14 of 17 Old 05-31-2019, 08:44 PM
fishinbama
2007 WK
178,000 miles
alternator
starter(was turning slowly)
glow plugs
crank sensor
other normal maintenance
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #15 of 17 Old 06-01-2019, 02:05 AM
rokrau
2008 WK
140,000 miles on my 08 CRD. Bought at 89,000 three years ago. Diff fluids changed when I got it. Then deleted the kidney. On my 3rd Turbo Actuator. CB-E Intercooler, Bosch Alternator, Reman Power Steering Pump and hoses. All new glow plugs. 7500m Oil changes. New brakes (today).
Gonna do a tranny fluid change next week when I can move again.
Have a total love-hate relationship with this car.
rokrau is offline
