What roof rack to get - JeepForum.com
post #1 of 8 Old 01-21-2020, 04:19 AM Thread Starter
browningv308
07 Overland CRD If money was no object what roof rack would you buy and why?
I've been thinking about putting a rack on the roof for extra gear and a spare tire since a 265 won't fit in the factory spare location. I see racks for $149 all the way to $500
Only special thing I may actually bolt to the rack would be a rear flood light or light bar to help out with the reverse camera at night.
browningv308 is offline
post #2 of 8 Old 01-21-2020, 07:11 AM
badgerwithhands
2007 WK
265 is the width of your tire, not the diameter. There is a hitch mod that may be enough for you to put your spare back in its place.
As far as roof rack goes, that depends on what you plan to use it for, weight and volume. If its just for camping a couple of times with some small weight, even with the spare, a cheap Craigslist find can be all you need. I found some no-name rack on Craigslist for $30 when I needed one in a pinch and was sufficient. You could easily mount a light to it.
The factory rails are cheap plastic crap. Rocky Road Outfitters are the only ones making aftermarket roof rails, IIRC.
I made my own rails and am almost done with my roof rack. Having a child has proved difficult to get Jeep things done since her birth last year.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #3 of 8 Old 01-22-2020, 06:20 AM
moonvan
2008 WK
The Gobi rack is nice but is by far the most expensive. It does have a lot of options for it though.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #4 of 8 Old 01-22-2020, 03:57 PM Thread Starter
browningv308
Wow, money is an object when it comes to a $1600 for a Gobi Rack, I saw a no name rack at Sportsmans Ware House last weekend It was assembled and on a display in the camping area. Flimsy as ever
Then the other day I was checking out a used Tahoe that had a rack on it, that rack could have served as a landing pad for a helicopter. Couldn't find a name on it though.
I ask for a good name because I like to buy stuff once.
post #5 of 8 Old 01-23-2020, 01:40 AM
LouC
2007 WK
We put a Kargomaster on our 98 ZJ about 5 years ago, good quality and you could get custom mounts for the ZJ roof rails. Then it was about $450, if I wanted a rack for the WK I’d check that one out....
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #6 of 8 Old 01-23-2020, 09:23 AM
LouC
2007 WK
http://kmsafaristore.com/en/bushman-...ket-rack.html?
You'd just need to figure out the mounts.
LouC is offline
post #7 of 8 Old 01-26-2020, 09:08 PM
Brill
2006 WK
I have this one on my WK:
https://www.amazon.com/59504-V-Tex-R...s%2C174&sr=8-1
Solid and not that expensive.
Brill is offline
post #8 of 8 Old 01-27-2020, 02:47 PM
2005JGC
2005JGC's Avatar
2005 WK
Build your own! haha
This will eventually be made out of aluminum, have a front fairing with an integrated 40" light bar with 80/20 extruded aluminum cross bars. The one quote I have now is 350 just to get the side plates laser cut. Then 200 for the extruded aluminum. Its on the to do list but after building the rear bumper with a dual swing-out.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
