What the hell is this......???? - JeepForum.com
 6Likes
  • 1 Post By WKjeepster
  • 1 Post By acabtp
  • 1 Post By Vertisce21
  • 3 Post By Mainsail
post #1 of 14 Old 05-05-2021, 06:57 PM Thread Starter
lacostadr
Discovered this behind my rear wheel it looks like a mini shock absorber..........what exactly is it called and what does it do???
lacostadr is offline
post #2 of 14 Old 05-05-2021, 07:13 PM
SteveROntario
That's the sway-bar link. You need one on each end of the sway-bar.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #3 of 14 Old 05-05-2021, 07:59 PM
Rick_H
2005 WK
Rick_H is offline
post #4 of 14 Old 05-06-2021, 03:21 AM Thread Starter
lacostadr
Thanks so ;much for the info.
The links I have look rusted/old and I would like to replace them. Is the job as simple as it looks?
post #5 of 14 Old 05-06-2021, 03:41 AM
WKjeepster
Pretty much......
underscore likes this.
WKjeepster is offline
post #6 of 14 Old 05-06-2021, 06:08 AM
acabtp
2005 WK
There is no reason to replace the pictured part
'05 WK Limited 5.7 Hemi
acabtp is offline
post #7 of 14 Old 05-06-2021, 08:57 AM
Vertisce21
Agreed. It's perfectly fine. Replace it with a new one if you wish but it's just going to end up looking like that again in a couple years. If you really want to make it look nice, take it off, clean it off, paint it and put it back on.
nwoods likes this.
Vertisce21 is offline
post #8 of 14 Old 05-06-2021, 03:11 PM Thread Starter
lacostadr
Parts already ordered ($30) for the pair.
I'd rather not have to deal with the old links failing at all............
post #9 of 14 Old 05-07-2021, 02:53 PM
underscore
What makes you think it's going to fail?
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #10 of 14 Old 05-07-2021, 05:27 PM
Vertisce21
For $30 he gets to pull out the old parts and see the rest of his suspension components under there. More than likely, he will find parts that actually need to be replaced.
post #11 of 14 Old 05-07-2021, 09:56 PM
GRAND420
GRAND420's Avatar
The best way to learn is to just jump into **** lol
GRAND420 is offline
post #12 of 14 Old 05-14-2021, 07:57 AM
Mainsail
2005 WK
There's so much wrong here....
OP, you want to replace a perfectly good part (that really looks nothing like a shock absorber) because you want to prevent it from failing, even though the ones you have will last as long or longer than the rest of the vehicle? ��
Please tell me you understand torque and bolt stretch, and know what value to set your torque wrench when you tighten the bolts. I hope they come right off for you, and don't break....
SKALA308, acabtp and underscore like this.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #13 of 14 Old 05-17-2021, 12:49 AM
2007laredowk
2006 WK
I recently replaced mine but the boot was torn and the ball joint was exposed and crusty aka needing replacement, besides I upgraded to SRT ones.
2007laredowk is offline
post #14 of 14 Old 05-17-2021, 12:40 PM
SKALA308
2010 WK
This is one weird thread
2010 WK 5.7 Eagle Head hemi
SKALA308 is offline
