Upgrading factory stereo - JeepForum.com
 1Likes
  • 1 Post By Timmmah
post #1 of 7 Old 08-17-2019, 09:11 AM Thread Starter
Timmmah
I have a 2008 wk diesel, and the factory radio has no sound. I'm assuming the amp isn't working, it's the Boston acoustic system. Gave an aftermarket amp and navigation deck I'd like to install. I have no problem with running all new wires to speakers and I have no desire to use factory wiring, but u want to retain all factory options like door chimes an such. My steering wheel has no radio controls, just has buttons for the user dash interface. What module do I need? I'm having trouble figuring this out. Thanks
Timmmah is offline
post #2 of 7 Old 08-17-2019, 12:30 PM Thread Starter
Timmmah
Also, can I just install my new head unit, amp and all wiring without a Pac module? As stated, I don't have any steering wheel controls to worry about.
Timmmah is offline
post #3 of 7 Old 08-19-2019, 07:03 AM
ggrassmid
2008 WK
You need the PAC module to communicate via the CANBUS system that the BA sound system runs on. You cannot just swap the heads units on those.
Have you checked all the fuses for the amp? The amp sits behind the left rear inside trim panel
ggrassmid is offline
post #4 of 7 Old 08-19-2019, 01:17 PM Thread Starter
Timmmah
I checked fuses for radio, they are good (radio is working, just no sound). Is there a fuse on the amp itself? I pulled Wire harnesses from the amp and reconnected but nothing.
Timmmah is offline
post #5 of 7 Old 08-19-2019, 02:58 PM
ggrassmid
2008 WK
http://wkjeeps.com/wk_fuses.htm
Cavity 1 on the interior fuses lists the amp, takes a 30am fuse
post #6 of 7 Old 08-19-2019, 04:40 PM Thread Starter
Timmmah
Thanks will check that
ggrassmid likes this.
Timmmah is offline
post #7 of 7 Old 08-24-2019, 06:56 PM Thread Starter
Timmmah
Ok finally onto checking it out today. Fuses good and checked harness at the amp and it's getting power on both power wires, and ground is good as well. There was a slight bit of corrosion in the amp. Pulled the board out of the amp to check it out and found the corrosion.
So the amp must be fried, didn't find any wet spots. So I want nothing to do with the stock BA system. Do I still need the Pac module to install my pioneer HU and aftermarket amp? I have no problem hunting for vss wires and running rcas and such.
Timmmah is offline
