Unknown connector hanging down - JeepForum.com
post #1 of 4 Old 04-15-2019, 02:28 PM Thread Starter
Paulrm
Hi all, I have a 5.7hemi can anyone identify this connector hanging below the engine??
Paulrm is offline
post #2 of 4 Old 04-16-2019, 09:52 AM
badgerwithhands
2007 WK
Breather for the front differential, I believe. Could be for transfer case or transmission. Should have a little "loose" cap on the back side of the image. The loop is to attach to a bolt. Get that thing up high. The front diff breather, on a CRD, at least, is mounted on the passenger wheel well where the coolant reservoir sits.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #3 of 4 Old 04-16-2019, 12:15 PM
consumedbywater
Similar mounting point with the Hemi, it'll fit right onto the overflow tube connector on the coolant reservoir.
consumedbywater is offline
post #4 of 4 Old Yesterday, 02:57 PM Thread Starter
Paulrm
[QUOTE=badgerwithhands;40589289]Breather for the front differential, I believe. Could be for transfer case or transmission. Should have a little "loose" cap on the back side of the image. The loop is to attach to a bolt. Get that thing up high. The front diff breather, on a CRD, at least, is mounted on the passenger wheel well where the coolant reservoir sits.
Great thanks for info much appreciated
Paulrm is offline
ggrassmid
Unknown Issue: Knocking coming from under TJ when decelerating Eric6123 TJ Wrangler Technical Forum 18 04-16-2019 08:09 AM
Unknown smoking on or by engine Jeff Myren WK Grand Cherokee & XK Commander Forum 10 02-07-2019 03:26 PM
Unknown Lift Height? Ashgrove07 Complete Lift Kits 0 05-12-2018 11:10 PM
unknown mercury switch WranglerTJEst Audio, CB & Ham Radios, GPS, & Electrical 7 12-30-2017 12:19 PM
