U1411 fault won't go away - JeepForum.com
 1Likes
  • 1 Post By marcus2137
post #1 of 3 Old 09-09-2020, 04:02 PM Thread Starter
marcus2137
I need to have my 2007 5.7 4x4 WK smog checked but there is a code. It's u1411. Based on searches I picked up a new ignition switch and replaced it. Nothing has changed, I still get the code and it won't let me clear it. I have no symptoms besides the CEL/code.
Any ideas?
Thanks.
marcus2137 is offline
post #2 of 3 Old 09-09-2020, 05:06 PM Thread Starter
marcus2137
Update, I figured it out. Hopefully this might help someone else in the future.
I had recently swapped my gauge cluster because our cluster was tampered with when we bought the Jeep (odo rolled back and CEL deactivated). I can't pass smog with the tampered gauge cluster, so I got another from eBay. Despite saying it would work with my 5.7L on the back of the cluster, it turns out I get the u1411 code every time I put the new cluster in, which otherwise works perfectly. When I put the old cluster back in, the code is gone. The part numbers or the clusters are slightly different (came from same spec Jeep, just 2005 vs my 2007), so I guess it's enough that it throws the u1411 code. Gonna return the new cluster, hopefully and try to find one with the same part number.
thearborbarber likes this.
post #3 of 3 Old 09-19-2020, 07:11 PM
Meritman
2007 XK Commander
I got this same code also U1403.. I have changed the ignition switch and so far problem has not been back but only been few days...with the 14 codes I would also get open circuit on a few cylinders and not all on same side.. 4.7 v8..don't know if's correction is done but sure is running lots better
Meritman is offline
