Turning my 2009 Jeep Grand Cherokee Limited to an SRT8? - JeepForum.com
 2Likes
post #1 of 17 Old 02-10-2019, 02:46 PM Thread Starter
PRIEST333
Can it be done 2009 Jeep SRT8 eng, trans, placed in 2009 Jeep Grand Cherokee Limited?
PRIEST333 is offline
post #2 of 17 Old 02-10-2019, 08:21 PM
caulk04
2008 WK
Possible sure I guess. Foolish yes.
Upgrade what you have.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 17 Old 02-11-2019, 08:29 AM
moonvan
2008 WK
I'm sure you can get it to bolt in but the electronics integration is probably not going to be easy. I agree it's probably easier to just upgrade what you have or sell it and buy an SRT if that is what you are after.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #4 of 17 Old 02-11-2019, 07:47 PM
Bangarng
2010 WK
Yeah man definitely. The SRT8 has the same transmission as the others except for the 5.7 HEMI and the engine will fit no problems.
I am not sure if the exhaust will match up perfectly or anything about the ECU, however.
Bangarng is offline
post #5 of 17 Old 02-12-2019, 05:43 AM
caulk04
2008 WK
Wrong.
3.7 and 6.1 both use the NAG1 trans, though I believe they are slightly different versions.
4.7 and 5.7 both use the 5-45RFE.
Bottom line is this: If the OP is asking this question, he's likely not capable of doing the swap. We're pretty much feeding a troll here.
acabtp and underscore like this.
caulk04 is offline
post #6 of 17 Old 02-12-2019, 08:22 PM
Bangarng
2010 WK
Originally Posted by caulk04 View Post
Wrong.
thanks for the correction.
Bangarng is offline
post #7 of 17 Old 02-13-2019, 04:22 AM
caulk04
2008 WK
Bangarng - Sorry, didn't mean that to sound so dickish. Was instead intending a much more informative tone.
caulk04 is offline
post #8 of 17 Old 09-07-2020, 08:53 AM Thread Starter
PRIEST333
That was Dickish I’m capable of many things and if I don’t know I ask questions to become informed anyways maybe I should have been more clear with my question have a 2009 Jeep Grand Cherokee SRT8 front wrecked up to radiator damaged frame everything else fine can I basically swap everything from SRT8 to 2009 Jeep Grand Cherokee Limited Body?
post #9 of 17 Old 09-07-2020, 06:50 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Just swapping the 6.1 engine and exhaust, WITHOUT the transmission and transfer case, would be the easiest way to go about this. You'd for sure need to get a tune for it though. The engines are pretty much identical except for the exhaust and, since you're doing a VVT to a VVT you probably won't have too much of an issue with the cam phaser settings, at least nothing that couldn't be fixed with a good tune. If you change the transmission and transfer case over to the 6.1 stuff, you'll have a lot of grief, as indicated above.....they're both very different. IMO, you'd also need to do some upgrading to the 545RFE transmission so it'll work satisfactorily behind the 6.1 which has probably 70 or so more hp than your current 5.7. There may also be a few other electronic glitches too.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, AFE Air Filter, 6spd 545RFE, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS and HP tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads w/new valve seats, SRT Reps with 265/45&295/40X20's. Also 05 Hemi LX modded exactly like WK and Comp Cammed 06 300CSRT8.
90grandoneer is offline
post #10 of 17 Old 09-07-2020, 08:58 PM
yzjwk
yzjwk's Avatar
2005 WK
I donít believe the 2009 - 6.1L is a VVT engine. If thatís the case then the swap would be quite a bit more in depth.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #11 of 17 Old 09-07-2020, 10:34 PM
bobwatford123
2006 WK
I'm just trying to figure out why the original poster took 7 months to respond back to the thread......and get all huffy about the answers he received
bobwatford123 is offline
post #12 of 17 Old 09-08-2020, 02:12 PM
caulk04
2008 WK
Like I said. Troll.
caulk04 is offline
post #13 of 17 Old 09-08-2020, 07:24 PM
90grandoneer
2006 WK
I didn't know that.
post #14 of 17 Old 09-08-2020, 09:49 PM
Gray203m
2008 WK
If you were to do this, the best way would probably be to swap literally as much as possible from the srt8 to the other Jeep. Engine, transmission, both axles, front CV axles, ECU, BCM, engine harness, transmission shifter, probably engine subframe and transmission cross member, maybe even the gauge cluster? Hell, I would swap the brakes too, and the suspension. Basically an SRT8 without the body kit.
The structural portions of the body will be the same, so theoretically every part of the srt8 should bolt right in.
2008 WK CRD North
GDE Eco Tune, DPF Delete
2" RC lift, 265/65R18 Duratracs
Gray203m is offline
post #15 of 17 Old 09-16-2020, 11:12 PM Thread Starter
PRIEST333
Took so long due to Covid and money situation if you wanna know huffy ok even said it was dickish but I was upset anyways like I stated I own the wrecked SRT8 because the frame was damaged I want to swap everything over someone said just swap the VIN’s but not wanting to go that route so I ask you folks for guidance and make me fool dumb for wanting to know ... thank you for the help you have given
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
2006 Jeep Grand Cherokee Limited longboy Jeeps For Sale 2 01-21-2019 07:55 PM
(New to me) 2007 Jeep Grand Cherokee Limited weavil WK Grand Cherokee & XK Commander Forum 1 06-11-2018 03:29 PM
1994 Jeep Grand Cherokee Limited 5.2L Slow turn issues 1994JeepGC ZJ Grand Cherokee Forum 6 04-16-2018 01:51 PM
2009 Jeep Liberty new (to me) engine problem NancyLou Engines & Drivetrain 0 03-04-2018 06:37 PM
