Transmission Question - NAG1 Vs 545RFE - JeepForum.com
 2Likes
  • 1 Post By cmdrjim
  • 1 Post By Penguin_Jeep
post #1 of 10 Old 01-12-2011, 11:20 PM Thread Starter
indianajeep
indianajeep's Avatar
2016 JK Wrangler
Here's one of those issues that causes me to say, now why did they do that? Ok, the new Challengers with the HEMI engines have the NAG1 Transmission. But the WK's with the HEMI engines have the 545RFE transmission - why? Wouldn't it seem logical to have the same transmission behind the same engines in these two applications? I have not had any issues with the NAG1 in my 05WKJ or with the NAG1 in my wife's 08 Dodge Nitro RT with the 4.0L engine (there was a wiring harness problem that cooked 2 tranny control modules in the Nitro - but since they fixed that over a year ago, no issues - knock on Mopar sheet metal).
indianajeep is offline
post #2 of 10 Old 01-13-2011, 01:01 PM
Budasac
Budasac's Avatar
2005 WK
I'm pretthy sure the SRT WK also has the Hemi and a Nag1. For some reason I believe it has to do w/ the transfer case. The 3.7 and SRT w/ the Nag1 have no 4 wheel Low option.
Budasac is offline
post #3 of 10 Old 01-14-2011, 03:53 AM
TJ9999
The NAG1 transmission has no Low Gear.
*** 2004 TJ Rubicon 4.7L Stroker / 42RLE / NV241 / 3" lift / 34" tires ***
TJ9999 is offline
post #4 of 10 Old 01-14-2011, 07:26 AM
cmdrjim
2006 XK Commander
Actually, the 3.7L V6 QT1 AND SRT8 use single speed transfer cases. The 3.7L uses the NV140 and the SRT8 uses the NC146 transfer case. So no low gear from the transfer case.
However, if you look at the gear ratios of the NAG1 all the gears are lower then the transmission in the 4.7L & 5.7L.
Personally the fact that Jeep put this transmission behind the 6.1L V8 of the SRT8 gives me a feeling of security having it behind my 3.6L V6.
luckyse7ens likes this.
cmdrjim is offline
post #5 of 10 Old 01-14-2011, 07:30 AM
meep
2008 WK
i like the nag1 on my wk. it seems very picky with fluid quality. i've swapped it twice, and both times the shifts have become different. not bad, just slightly different.
meep is offline
post #6 of 10 Old 01-14-2011, 07:36 AM
meep
2008 WK
OEM plugs were NGK!
08 WK 3.7 2wd.
Finally did plugs last night at 31k miles. I bought champions to stick in there after all of the pretty much common knowledge that champions were oem, jeeps prefer champions (especially the v8s). So out comes NGK ZFR6F-11G.
They all came out with .045-.046 gap. stock I think is .043, depending on where you read it.
Other tidbits.
What a cute little throttle body!!! I want to say my 2.2L subaru had a bigger one! It was, for all practical reasons, clean and needed zero help in that area (I only run synthetic oils at 6,000 mile intervals).
Champion Plats went in, runs fine. No real change in performance, tho it feels a touch smoother.
The plugs came out with WAAY different amounts of tightness! Some just came out, some had to be wrenched pretty good (for plugs). Considering I had the same experience with brake bleeders on this thing (one snapped off), I think the assembly QC must be pretty pi$$-poor.
Anyway, new info. (?) NGKs are oem in the 08 3.7.
M
meep is offline
post #7 of 10 Old 09-08-2016, 05:05 PM
Penguin_Jeep
2006 WK
Low range is determined via the transfer case!
Penguin_Jeep is offline
post #8 of 10 Old 09-08-2016, 05:09 PM
Penguin_Jeep
2006 WK
My 3.0 CRD rolled off the production line 21st June 2005, the Miles are around 112,000
My handbook says it doesnt need doing... Like the Mercedes we have owned for 15 years now (C320) on 200,000 miles is also claims to be a lifetime fill.
Both seem to run 100% - no shifting issues.
When did you change out your Jeep Tranny fluid?
post #9 of 10 Old 09-08-2016, 05:42 PM
luckyse7ens
2010 XK Commander
"lifetime" really just means... it will last longer than the factory warranty. So they don't have to change it on their dime.
Black WK Club #152
luckyse7ens is offline
post #10 of 10 Old 09-08-2016, 05:44 PM
luckyse7ens
2010 XK Commander
Lol you dug this up from 2011!
Black WK Club #152
Poor Man's NAG1 Transmission Service/Check ssherm_2 WK Grand Cherokee & XK Commander Forum 2 07-02-2013 02:26 PM
Mercedes spec transmission fluid 236.14 for NAG1/wa580/w5j400 fishinbama WK Grand Cherokee & XK Commander Forum 13 06-14-2013 10:59 AM
NAG1 Transmission Fluid Change question. Overfilled? wookiee WK Grand Cherokee & XK Commander Forum 11 04-27-2012 10:11 AM
Changed Transmission Fluid, Filter and Gasket In 05 WK Laredo, w/3.7 and Nag1 Tranny indianajeep WK Grand Cherokee & XK Commander Forum 3 12-26-2010 08:40 AM
Question about replacing the Transmission Speed Sensors on the 545RFE Soft 8 ZJ Grand Cherokee Forum 3 01-05-2008 09:53 AM
