Transfer case noise - JeepForum.com
 1Likes
  • 1 Post By yzjwk
post #1 of 9 Old 01-17-2020, 04:21 AM Thread Starter
jrv8984
Transfer case noise
In awd Clunking noise when shifting it in and out of drive/reverse Noise sounds like an intermittent screeching rotational sound. It doesn't make the sound in 4 lo?
Transfer case or transfer case motor?
jrv8984 is offline
post #2 of 9 Old 01-17-2020, 09:12 AM
marka2k
marka2k's Avatar
2006 WK
Visually check the propeller shaft from the TC to the front Differential if you have not already.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #3 of 9 Old 01-17-2020, 11:38 AM
yzjwk
yzjwk's Avatar
2005 WK
Clunking when shifting P-D/R and D-N/R is usually the front differential bushings.
Nothing is turning at that point until you take your foot off the brake.
underscore likes this.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #4 of 9 Old 01-17-2020, 01:33 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hello jrv8984,
We are certainly sorry to hear about your recent clunking concern. If you're not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please let us know via private message. We would be more than happy to provide you with an additional layer of assistance for that process.
Laura
JeepCares
JeepCares is online now
post #5 of 9 Old 01-17-2020, 05:50 PM Thread Starter
jrv8984
Does that explain the screaching noise that is coming directly from the transfer case. This was while it was up in the air, all tires spinning in drive.
jrv8984 is offline
post #6 of 9 Old 01-17-2020, 06:06 PM
yzjwk
yzjwk's Avatar
2005 WK
Don’t know, but clunking when shifting in and out of gear is certainly front differential bushings.
How’s the transfer case fluid color/level if you’re sure the noise is coming from there ? How are the input and output shafts ? Prop shaft?
If you fill out your profile , we’ll at least know what engine/drive system you have.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #7 of 9 Old 01-18-2020, 06:30 AM Thread Starter
jrv8984
3.0 crd, Quadra drive 2
jrv8984 is offline
post #8 of 9 Old 01-25-2020, 04:20 PM Thread Starter
jrv8984
Replaced the front axle mounts. That helped, but I still have rotational noise while driving, coming from the front end. Cv boots looked good. Other than maybe the tires being out of balance, I'm at a loss.
jrv8984 is offline
post #9 of 9 Old 01-27-2020, 11:39 AM
Xmind
2007 WK
Check the diff fluid level? Possibly the fluid is low and bearings are dry when first starting out?
'07 GC CRD QDII
Xmind is offline
