Strange idle at normal operating temps - JeepForum.com
post #1 of 5 Old 02-25-2020, 08:00 PM Thread Starter
rockawaywk
2006 WK
My 4.7 has some random idle issues at normal operating temperatures. It will bog down to 400-500 RPM once in a while and is very noticeable. Anyone have a similar issue and resolved it? What should I check?
rockawaywk is online now
post #2 of 5 Old 02-27-2020, 04:16 AM
caulk04
2008 WK
Once upon a long time ago I had a truck with a 4.7 and had this issue for a while. My solution ended up being the IAC motor.
On the drivers side of the throttle body are two items. The upper is the TPS (throttle position sensor). The lower is the IAC (idle air control) motor.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 5 Old 02-28-2020, 11:57 AM
84dime
I second looking at the IAC. They can cause all sorts of weird idle issues.
2006 Liberty
2005 Grand Cherokee
84dime is offline
post #4 of 5 Old 03-01-2020, 06:17 AM Thread Starter
rockawaywk
2006 WK
Thanks guys. IAC valve going in today. Let’s see if that solves the problem.
post #5 of 5 Old 03-05-2020, 07:10 PM Thread Starter
rockawaywk
2006 WK
Problem solved! IAC fixed it. Thanks guys.
