Starting problem - JeepForum.com
post #1 of 3 Old 07-06-2021, 09:56 AM Thread Starter
Lenny7
2006 WK
Starting problem
Won't turn over or even try. Only rapid clicking. It will jump start. Went to auto zone and they checked the battery and they said it was fine. After I jumped it, on the way to auto zone, the blinkers would blink rapidly, like when a bulb is out and the windows wouldn't roll down. After I killed it, it restarted just fine and then the blinkers and windows worked normally. After I got home and killed it, it wouldn't start, only clicking. I'm a youtube hack mechanic at best, any ideas? Bad starter? The blinkers and windows seem like a weird symptom. My neighbor said he had similar problem and it was a bad starter relay. Replaced that but no luck.
Lenny7 is offline
post #2 of 3 Old 07-07-2021, 12:05 PM
nwoods
2006 WK
It feels like a bad alternator to me. It's kind of a IPIA, but you can remove it and bring it back to AutoZone and they can bench test the alternator's health.
2006 Jeep WK on 33ís
HAM: KI6FPO
Offroad Photography:
nwoods is offline
post #3 of 3 Old 07-07-2021, 12:16 PM
yzjwk
yzjwk's Avatar
2005 WK
If the solenoid is clicking rapidly, that usually means your battery is low and if it starts every time with a boost than that pretty much
guarantees your battery is low.
Don’t ever trust those stupid battery testers at the auto stores most of them are crap.
A voltage check while the car is running is usually a pretty good indicator if your alternator is working or not. You should have 13.5 to 14.5 V DC with the engine running. Use a new or charged battery because continually having the alternator charge the battery will kill the alternator.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
