Spacers?? - JeepForum.com
 7Likes
  • 1 Post By caulk04
  • 1 Post By TackleberryWK
  • 1 Post By YouStupidBunny
  • 1 Post By Raffish
  • 1 Post By underscore
  • 1 Post By Planetcat
  • 1 Post By Mainsail
post #1 of 8 Old 10-15-2019, 09:38 PM Thread Starter
AlaskanCelt
Spacers??
Alright I know this is a huge topic and there are people on both side. I have a 2005 Jeep WK and was looking into getting 1"-1.5" spacers to widen the stance or the ol gal. I've seen it done and it just makes them look way better imo. How much would it negatively effect everything? Is it worth it? Or is there another way of doing it?
Thanks in advance!
Sent from my SM-G965U using Tapatalk
AlaskanCelt is offline
post #2 of 8 Old 10-16-2019, 08:06 AM
caulk04
2008 WK
Spacers or wheels with different specs (width, offset, or backspacing).
Spacers are fine, IF they are quality parts and used properly. My 1.25" spacers have been trouble free for a few years now. I have one pair from Bora and one from SpiderTrax. Both are good.
AlaskanCelt likes this.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 8 Old 10-16-2019, 08:54 AM
TackleberryWK
TackleberryWK's Avatar
2010 WK
I have a set of Rough Country 1 1/2" wheel spacers that are working well for me. Good quality stuff.
"A bad day shooting is better than any day working."
TackleberryWK is offline
post #4 of 8 Old 10-16-2019, 09:47 AM
YouStupidBunny
YouStupidBunny's Avatar
2007 XK Commander
A proper wheel spacer should be secured to the factory studs. The wheel then secures to the studs built into the hub centric spacer. If the spacers are well made with quality materials, they are no different than using a wheel with similar backspacing.
When people talk negatively about wheel spacers, I think they are referring to the type that push out the wheel and reuse the same studs and nuts. Those type hang on with much less thread and I think everyone will agree they are less safe. I've never heard of a proper wheel spacer failing that wasn't because of an improper installation. The only two times I've seen them fail was because the nuts backed out.
YouStupidBunny is offline
post #5 of 8 Old 10-16-2019, 09:57 AM
Raffish
2005 WK
Spacers will push your wheels out and increase the forces on the wheel bearings and cause premature failure. Especially with a lift and over-sized tires.
Wheel bearings are relatively easy to replace. (If originals are really stuck remove the whole knuckle and hit with a BFH and they'll pop right out, use never seize when reinstalling and easy next time)
Get ones with a lifetime warranty..
Torque spacers correctly.
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, MBRP SS, 250xxxkms
Raffish is offline
post #6 of 8 Old 10-16-2019, 01:07 PM
underscore
2007 WK
I've used both bolt on and slip on spacers on multiple vehicles for years without issues. Both are perfectly safe when used correctly and hazardous when used incorrectly, just like anything else. As others have said the increased strain on things like wheel bearings is no different from the equivalent offset rims.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #7 of 8 Old 10-17-2019, 09:21 PM
Planetcat
2010 WK
Same here. About 50k miles and no problems. Also had them on my WJ and XJ. Get good quality, hub centric ones like spidertrax or rough country and you will be fine. Make sure you torque them to specs too.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #8 of 8 Old 10-18-2019, 08:23 AM
Mainsail
2005 WK
I've always considered spacers to be the 'bubba fix' - cheap and easy. I went with wheels (AEV Pintlers) that do the same thing.
I'm always glad to hear people say their spacers are working great- but they're not for me.
acabtp likes this.
Poor grammar is something up with which I shall not put.
Mainsail is offline
