Smaller rims touching calipers - JeepForum.com
 6Likes
  • 1 Post By HAZCAT
  • 3 Post By underscore
  • 2 Post By acabtp
post #1 of 8 Old 05-14-2019, 01:11 PM Thread Starter
jrduke01
2007 WJ
So I decided to change my aluminum rims to steel and the rims I got are 1 inch smaller and hit the brake calipers on the front. Should I use spacers, grind the calipers down or change the rotor and caliper to be smaller?
jrduke01 is offline
post #2 of 8 Old 05-14-2019, 02:16 PM
acabtp
2005 WK
what size wheels did you buy?
'05 WK Limited 5.7 Hemi
acabtp is offline
post #3 of 8 Old 05-14-2019, 02:46 PM
HAZCAT
HAZCAT's Avatar
I ground down the calipers when I did a disc brake conversion on my CJ after putting the Chevy 1 ton 14 bolt rear axle in to fit my 15" steel wheels. I didn't have to take off much and it is still tight in there but as long as the wheel is free to roll you are fine.
2005JGC likes this.
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
post #4 of 8 Old 05-14-2019, 04:14 PM Thread Starter
jrduke01
2007 WJ
I'll try that,I didn't want to weaken the caliper if I took too much off.
jrduke01 is offline
post #5 of 8 Old 05-14-2019, 04:36 PM
underscore
2007 WK
Changing to smaller brakes on a 5000lb+ SUV generally isn't a good idea.
acabtp, 2005JGC and BadExample like this.
07 WK CRD//QDII//OME MD//OMG WTF BBQ [daily]
91 Celica GTFour RC [for sale]
underscore is online now
post #6 of 8 Old 05-15-2019, 02:42 PM Thread Starter
jrduke01
2007 WJ
So I'm grinding off a lot of the caliper to try and fit these wheels on. The stock disc is 13 inches, would it be ok to go to a 12 inch drilled and slotted disc with new calipers to match?
jrduke01 is offline
post #7 of 8 Old 05-15-2019, 05:48 PM
acabtp
2005 WK
no, it would not be ok.
why are you even thinking of that instead of just getting wheels that fit?
yzjwk and underscore like this.
acabtp is offline
post #8 of 8 Old 05-16-2019, 01:10 PM
caulk04
2008 WK
What the hell? You bought the wrong size wheels, so you're going to spend money on smaller brake parts and effort making them work rather than use the right size wheel?
Good luck getting something smaller to work in there. Best to just stop working on vehicles.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
Akebono Front Calipers For My 2003 torchd WJ Grand Cherokee Forum 6 05-15-2019 12:15 PM
Rims vs Rims vs Rims Chick-N-Picker3 XJ/MJ Cherokee Non-Technical Forum 4 05-14-2019 03:44 AM
Installation of PowerStop front calipers. Uniblurb WJ Grand Cherokee Forum 27 06-03-2018 05:49 AM
Best advice/product for cleaning tarnish off Chrome Clad rims Curlybandit WK Grand Cherokee & XK Commander Forum 0 05-16-2018 08:09 AM
A-1 Cardone vs Power Stop reman brake calipers Uniblurb WJ Grand Cherokee Forum 13 04-07-2018 02:05 PM
