SKIM module won't sleep - JeepForum.com
post #1 of 5 Old 08-13-2019, 09:42 PM Thread Starter
NateS
My sentry key ignition module (SKIM) won't got o sleep after locking the vehicle. How I know it's the SKIM, battery started draining completely over night. Did a parasitic draw test resulting in the IOD fuse. Checked the wiring diagram and once the SKIM was disconnected the draw was gone.
Does the skim need to be replaced? I have completely reset the PCM with nothing changing. I'm at the end of my knowledge and need some help.
NateS is offline
post #2 of 5 Old 08-13-2019, 10:43 PM
yzjwk
yzjwk's Avatar
2005 WK
What year/ engine/ 4wd system?
05-07 sentry key is incorporated in the SKREEM module and includes the Wireless Control Module. 08-10 The WCM is now a WIN module and is separate. Either way, It’s very possible that something is keeping the module alive as opposed to the module just not going to sleep (damaged door contact, TPMS transmitter, module) . You’ll probably need a very good scanner to see what’s active after power down. FYI the IOD takes 3-5 minutes to power down with no other activity.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 5 Old 08-14-2019, 01:45 PM Thread Starter
NateS
2005/ 5.7/ 4X4
SO the SKREEM, SKIM ans WCM are all the same module? All I know is when I disconnect the little black box that is attached the the ignition the draw goes away. I have a very good scanner I just need to know what to look for.
NateS is offline
post #4 of 5 Old 08-14-2019, 11:23 PM
yzjwk
yzjwk's Avatar
2005 WK
Yes, WCM and SKIM are the same module. You need to be able to look at the WCM with your scanner and see what is keeping it awake. I donít have my FSM handy but I believe that could be anything on the CAN B network.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #5 of 5 Old 08-20-2019, 08:43 PM Thread Starter
NateS
So I wasn't able to figure out how to check on the scanner. I took a test light and unplugged the scream then tested the 8 wires going into the module both the white and grey/red wires turn the light on.
NateS is offline
