Sheet Metal Screws for Inner Fender? - JeepForum.com
 5Likes
  • 1 Post By JeepN_A_CJ7
  • 2 Post By acabtp
  • 1 Post By badgerwithhands
  • 1 Post By browningv308
post #1 of 9 Old 02-26-2020, 06:32 PM Thread Starter
CommanderRandy
2007 XK Commander
I've done the pinch weld mod, but I Haven't done anything to the 'bump' in the inner fender. I need to borrow a heat gun because I don't have one to get that bent back out of the way. I'm getting just minimal rub there with 255's using 1.5" spacers on the wheels.
But just pushing that liner around with my hand, it's nowhere near snug up against the actual fender in there. What's behind that in the 'bump' area? Can I just pop a couple of self tapping sheet metal screws in there and call it good? Or am I going to hit a wiring harness or something? What's behind door number 1?? Anyone? I almost think just holding that thing back up against the true fender would eliminate my rubbing issues. In these two pics you can see the difference in clearance just by pushing it back with my hand.
Thanks in advance...
Previous Jeeps: 89 YJ, 92 YJ, 99 XJ, 98 XJ
Current Jeep: 07 XK Commander limited w/HEMI
CommanderRandy is offline
post #2 of 9 Old 02-26-2020, 07:53 PM
JeepN_A_CJ7
JeepN_A_CJ7's Avatar
1980 CJ7
Exactly what I did, just added two self tapping screw on each side and it's good to go!
CommanderRandy likes this.
Always Jeepin!
*2007 WK QDII HEMI
*1980 CJ7 4.2L w/FAST FI
Silver WK Club
JeepN_A_CJ7 is offline
post #3 of 9 Old 02-26-2020, 10:09 PM
badgerwithhands
2007 WK
I drilled a small hole lower down and used a black ziptie. Easy to replace
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #4 of 9 Old 02-27-2020, 07:20 AM
acabtp
2005 WK
i drilled holes and used the same rivets that the fender liner itself uses. very secure.
a hole you drill ahead of time you can paint the exposed metal edges to stop rust. self tappers are a rust death sentence around here (we salt in the winter), especially in the wheel well area.
underscore and Raffish like this.
'05 WK Limited 5.7 Hemi
acabtp is offline
post #5 of 9 Old 02-27-2020, 08:41 AM
badgerwithhands
2007 WK
I failed to mention: I did a ziptie and drilled only through the plastic. I added zero holes to the sheet metal.
underscore likes this.
post #6 of 9 Old 02-27-2020, 03:39 PM Thread Starter
CommanderRandy
2007 XK Commander
Thanks guys. I think I'll go that route... maybe heat the 'bump' up with a heat gun and then bend it and secure with a sheet metal screw or 2. Sounds like no big danger of hitting something behind the fender with a screw??
Rust isn't really much of an issue for me in the high desert. Ziptie makes sense, but if there's nothing back there to hit with a screw I like the idea of a more permanent solution.
post #7 of 9 Old 02-28-2020, 08:27 PM
GRAND420
Glad I'm not the only one who's done this lmao
GRAND420 is offline
post #8 of 9 Old 03-01-2020, 06:00 AM
browningv308
There is a sensor behind the liner, I think it is the tpms sensor
badgerwithhands likes this.
browningv308 is offline
post #9 of 9 Old 03-01-2020, 08:20 AM Thread Starter
CommanderRandy
2007 XK Commander
Yeah that's up quite a bit higher though. Got familiar with that guy doing the pinch weld mod... and the rear air coolant lines are up there too on the passenger side. In the area right near the 'bump' in the fender liner (where the pinch weld used to stick out) there's nothing on the outward side... I was more worried about any wiring or anything that might be mounted on the inside of the fender out of sight. Doesn't sound like that's a concern in that area though....... ?? I'm just talking about a screw or two right down in the lower area where the pinch weld is.
