RPM Hesitation / Stuttering - Page 2 - JeepForum.com
post #16 of 17 Old 10-13-2019, 10:56 AM Thread Starter
sheridantj
I’ve been paying closer attention to the hesitation issue, and it seems to only happen when I’m in 4th gear at low rpms. Still think it may be a TCC solenoid?
Could low trans fluid be an issue? As far as I know, the trans has never been serviced. It’s an 09 with 114K.
sheridantj is offline
post #17 of 17 Old 10-13-2019, 02:54 PM
yzjwk
yzjwk's Avatar
2005 WK
If youíve narrowed the problem down to a specific gear then I would say Transmission problem - yes. Transmission fluid issue - unlikely
NAG1 transmissions seem to have an issue with conductor plates / valve bodies, but thatís still a guess. Should be put on scanner and possibly transmission diagnostics machine and have all the solenoids and valve body checked for proper actuation and flows.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
