Resolving P0720 - Output Shaft Speed Sensor ('08 CRD w/ W5A580/NAG1) - JeepForum.com
 4Likes
  • 1 Post By DrBenz
  • 1 Post By DrBenz
  • 1 Post By SteveROntario
  • 1 Post By badgerwithhands
post #1 of 8 Old 08-13-2020, 09:24 PM Thread Starter
Curlybandit
Hello everyone.
I'm looking at possibly picking up another '08 JGC CRD. I sold my '08 JGC Overland CRD this past November with 384,000km on it. This one has only 205k. The seller is an acquaintance and he contacted me to see if I would be interested in it as a parts vehicle as he assumed I still had my Jeep. It's been sitting for about a year at his cottage. I went to see it, charged the battery and got it running. It has a few codes, most of which I'm familiar.
Unfortunately, it does have a P0720 (Output Shaft Speed Sensor Circuit) code that I'm not familiar with. I came across an online W5A580 repair workbook and it appears that this transmission doesn't have an Output Shaft Speed Sensor. The other transmission found in the 4.7L and 5.7L versions does.
This transmission TCM uses the ABS wheel speed sensors to calculate the output shaft speed sensors.
If anyone has experience resolving this, please let me know. Is it a wheel ABS speed sensor that's causing the problem? Perhaps so, since there is also an ABS light (the dash might just look like a Christmas tree...).
Thanks.
Between Jeeps
Curlybandit is offline
post #2 of 8 Old 08-19-2020, 07:17 PM
DrBenz
DrBenz's Avatar
The transmission is the Mercedes 722.6, right? If it is the output shaft speed sensor is part of the conductor plate. You can order it separate and they are plug and play with no coding that needs to be done
Curlybandit likes this.
DrBenz is offline
post #3 of 8 Old 08-19-2020, 07:53 PM Thread Starter
Curlybandit
Hello Dr. Benz. Thanks for the reply. It is the MB 722.6. I'll look into the conductor plate and order from MB. I've had much better luck in the past getting parts from MB than Jeep.
Between Jeeps
post #4 of 8 Old 08-19-2020, 09:00 PM
DrBenz
DrBenz's Avatar
When u get it, to change it out you will have to remove the valve body. Replace the trans electrical connector at the same time. They are only like 25$ or so and when they fail they cause lots of problems down the road plus they leak constantly. The main thing is to torque the valve body bolts properly after installation. I have seen the 722.6 and 722.7 have issues where they won’t move or slip all because one or two bolts were left loose on the valve body to transmission bolts. It is a relatively simple repair minus making the mess and using 6-8 plus quarts of synthetic tranny fluid. Also replace the trans filter when doing the repair, might as well perform the full service if the valve body is coming out.
DrBenz is offline
post #5 of 8 Old 08-20-2020, 05:41 PM
SteveROntario
You can get the conductor plate from Dorman and it will be an MB part.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #6 of 8 Old 08-20-2020, 07:10 PM Thread Starter
Curlybandit
This is great info! Thank you!
Between Jeeps
post #7 of 8 Old 08-20-2020, 07:11 PM Thread Starter
Curlybandit
Great! Thank you
Between Jeeps
post #8 of 8 Old 08-22-2020, 09:43 AM
badgerwithhands
2007 WK
Very important to take note of the shifter arm. It is simple but also easy to miss when reassembling. A lot of the videos I saw in regards to this replacement do not mention it
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
