Replacing Stock Shocks - JeepForum.com
post #1 of 23 Old 03-29-2015, 06:48 PM Thread Starter
D.J._2000WJ
D.J._2000WJ's Avatar
Hey All,
I am looking to replace the shocks and struts on my mothers '07 WK. Her Jeep is strictly an everyday driver. zero towing, zero offroading. Anyone have a suggestion on good OEM or near OEM shocks and struts to buy? I am looking on rockauto and noticing that the MOPAR stuff is exponentially more more expensive than the Monroe or Gabriel stuff. Would I just be paying for the name? Rancho seems to be middle of the road... Also, as I am a WJ guy, I have never bought or replaced struts before... suggestions.. I appreciate it.
D.J._2000WJ is offline
post #2 of 23 Old 03-29-2015, 07:00 PM
BLKCRD
2008 WK
Bilsteins
I like my Bilstein WK. have them for almost 5 years now. Not a single problem.
'08 GC Diesel Limited/SRT8 Springs/Swaybar/Bilstein/OEM Sahara 18"/255/70/18/Pinch weld/GDE ECO
BLKCRD is offline
post #3 of 23 Old 03-29-2015, 07:06 PM
SilverLimited
2019 WK
I recently installed Monroe Reflex struts and shocks on our 2005 GCL.
Purchased them from Advance Auto - online and picked up at the local store. Used discount code TRT30 for 30% off. Monroe is also running a $60 rebate for the purchase of 2 shocks + 2 struts, or 4 shocks.
Have had good luck with the Monroe Reflex's, still running them in the 2001 Limited for several years.
15 WK2 Overland 3.6L QTII
05 WK Limited 5.7L QDII
01 WJ Limited 4.7L QuadraDrive
00 WJ Laredo-gone
SilverLimited is offline
post #4 of 23 Old 03-29-2015, 07:53 PM
TurboDiesel
TurboDiesel's Avatar
2008 WK
yep lovin the bilstein
just recently did 5100 in the rear
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #5 of 23 Old 03-29-2015, 09:35 PM
brentwoodkris
2005 WK
Love my Monroe reflex and LL's. 60k miles and going strong! Way better than the bouncy OEM ride!
brentwoodkris is offline
post #6 of 23 Old 03-29-2015, 10:11 PM
ColoradoGrand05
2007 WK
Bilstein 4600s are great
2007 WK, 4.7L
Colorado Jeep club #288
ColoradoGrand05 is offline
post #7 of 23 Old 03-30-2015, 05:42 AM
paroxysym
2007 WK
bilsteins are expensive compared to the bilsteins. ive DD my WK since I bought her, wheeled her twice, but the 80k ive racked up on her has been 99$ highway. ive been runningbilstein 4600s since I bought it and I don't think ill ever go with another shock on this jeep. even when I go back to running a lift, ill be going with a bilstein. if youre on a budget, I would def go Monroe- ran them on a lifted XJ and they were great. I plan on throwing them on my gfs TJ soon. Monroe also makes a quick strut assembly which comes assembled with a coil so you can swap them in and out quicker in the front and avoid the need for a spring compressor.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #8 of 23 Old 03-30-2015, 07:07 AM
RCS1300
2005 WK
I went Mopar because of the 12 month warranty. One of my new shocks was leaking oil after a week and they send another out two day air no questions asked.
http://www.justforjeeps.com/reshwkgrchli.html
They were hard to get a few months ago. Maybe everyone is now replacing and causing a shortage. Who knows.
RCS1300 is online now
post #9 of 23 Old 03-30-2015, 07:19 AM
brentwoodkris
2005 WK
IIRC, Monroe and most aftermarket struts and shocks may have a limited lifetime warranty. I've had some Monroe's on a vehicle for 100k+ miles and sold them with the vehicle...still in good working order. Never had to worry about a warranty replacement though. They could be one of those places that has a good warranty but ONLY if you have a "certified" installer put them in as a way to force you to pay for installation.
post #10 of 23 Old 03-30-2015, 07:41 AM
Nejeep
2019 WK
A few years back I replaced the worn out OE struts on a Cavalier with lifetime warranty Monroes from Adv Auto. After 100k the Monroes also wore out, so Adv Auto provided replacements, no hassles as long as you have the receipt. At least at that time, no certified installers were required, did it all myself.
19 Limited 4x4 3.6 White/Tan new daily driver
06 Laredo for 11 years
97 Laredo for 14 years
Nejeep is offline
post #11 of 23 Old 03-30-2015, 07:43 AM
brentwoodkris
2005 WK
Nice! Unfortunately I bought them on Amazon...I wonder how that would work...
post #12 of 23 Old 03-30-2015, 07:59 AM
paroxysym
2007 WK
correct, bilstein has a lifetime warranty.
OEM+
post #13 of 23 Old 03-30-2015, 10:51 AM
caulk04
2008 WK
Sounds like the best choice may be whatever you can get cheapest.
Otherwise, I'd go with Bilstein 4600's from Kolak. He'll have a good price.
Being in Jersey, I'd plan on buying two new lower strut fork bolts and two new LCA/Strut fork bushings. If the bolt wont come out, cut it inside the fork with a 4" grinder, destroy the bushing rubber and cut the sleeve out then press new bushings in. I could do the job over again with stuck bolts in just a couple hours.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #14 of 23 Old 03-30-2015, 01:44 PM
luckyse7ens
2010 XK Commander
I have run Bilstein's on my Jeep, KYB monotube Monomax on my Tbar cranked F150, and I have some Gabriel max control monotubes in the garage waiting to be installed on my Denali. I prefer monotube shocks obviously.
The bilstein's have provided the best ride so far, but the KYB's were on a fullsize truck with the Tbars cranked to the max and LT tires so no shocks were going to make that a comfy ride. That being said control and handling improved immensely on that truck with those shocks.
I'd be willing to bet that you would be happy with a high quality shock from any of those manufacturers.
The gabriel's were by far the cheapest. They appear solid in comparison to the other two.
Black WK Club #152
luckyse7ens is offline
post #15 of 23 Old 03-30-2015, 07:34 PM Thread Starter
D.J._2000WJ
Thanks for the info. I had not thought about anything like that. I am sure 8 years of NJ road salt will have those bolts nice and frozen.
Thanks for your input everyone. I am pretty sure I am going to go with the Monroes. I was able to get that discount code locked in making it an easy choice. Besides, there is no way my mother's WK is getting Bilsteins before my WJ does.. I am still living with SkyJacker Hydro 7000s as a daily reminder of my poor judgement
