Replacing Starter and Bearings Myself - Brands?? - JeepForum.com
post #1 of 11 Old 11-05-2015, 07:59 PM Thread Starter
bmb063
2005 WK
Hi everyone. After taking my jeep for some aggressive off roading, maintenance has been draining my bank account... So I will be replacing the starter and front bearings with a friend in the next month or so.
The starter is caked with mud and makes a grinding noise sometimes at crank. The front bearings are dirty and noisy/rattly. I was quoted over $1k for parts and labor (for both jobs combined).
Here are the parts I am looking at. Any advice or tips for doing either job? I am not familiar with brands or why there might be a price difference. Thanks for the help!
Starters:
https://www.go-parts.com/0508-jeep-g...r-p-45257.html
http://www.thewrenchmonkey.com/auto-...uVwxoCP4zw_wcB
http://www.dbelectrical.com/p-14011-...iberty-07.aspx
Bearings:
http://www.discountbodyparts.com/cat...?dbpcid=gglpla
http://www.1aauto.com/jeep-wheel-bea...2FxxoC2mLw_wcB
bmb063 is offline
post #2 of 11 Old 11-05-2015, 09:06 PM
gjxj
you need to unbolt the front driveshaft to do the starter. Not a huge deal, just be aware its a little bigger job than you might expect. (and keep that in mind if thinking about a discount part)
gjxj is offline
post #3 of 11 Old 11-06-2015, 06:45 AM Thread Starter
bmb063
2005 WK
I've heard that you have to unbolt it too, but I found a youtube video showing how to avoid doing that...
And do those parts looks okay? Any to avoid?
bmb063 is offline
post #4 of 11 Old 11-06-2015, 08:34 AM
caulk04
2008 WK
www.rockauto.com
Buy them all together. Enter this code for 5% off: 3703497929048574
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #5 of 11 Old 11-06-2015, 11:23 AM
ryankokesh
2010 WK
What the heck were they smoking when they designed that...?
ryankokesh is offline
post #6 of 11 Old 11-06-2015, 11:35 AM
festerw
festerw's Avatar
Might just be me but I'd pay the extra cash and get Timken hubs, also if you have an Advance Auto close by you can order the starter from them online and use a discount code and get it for about the same price you're looking at and if you have problems with it you can get a new one without having to wait.
Hers - 2011 Dodge Durango Crew
Mine - 2004 Toyota Tundra DC SR5
festerw is offline
post #7 of 11 Old 11-07-2015, 07:16 PM Thread Starter
bmb063
2005 WK
Timken are 2-3x the price - that's pretty hard to justify since this is my main vehicle in winter and then just a second car in every other season. Unless the $70 ones are that bad, I will probably stick with them. Let me know your thoughts, thanks!
bmb063 is offline
post #8 of 11 Old 11-09-2015, 02:15 PM
1AAuto.com
1A Auto Parts
1AAuto.com's Avatar
We have a 2 year warranty on our economy wheel bearings. Our starters are brand new, not rebuilts. Our starters include a lifetime warranty with no core charge.
All orders include free shipping in the lower 48 states.
Tony
1AAuto.com is offline
post #9 of 11 Old 11-10-2015, 03:52 AM
RCS1300
2005 WK
Doing the labor yourself will take some significant time and patience mostly because of rust. Do yourself a favor and put in mopar parts so you do not have to do the job again in six months. Moparpartsdiscounted or another vendor that is a member of this site sells mopar parts at significant discount.
Sure, there are a lot of inexpensive parts available but most are from mainland China using low grade steel and poor tolerances - that is why they are inexpensive.
RCS1300 is offline
post #10 of 11 Old 11-10-2015, 12:24 PM
jimmyj02
It's actually a lot easier of a job than most starters. The starter has plenty of room to drop out once the drive shaft is out of the way and not like most where you have to fanagle the freaking thing 20 different ways to get it into position AND still have to put the + wire on!!!
jimmyj02 is offline
post #11 of 11 Old 11-12-2015, 11:07 AM Thread Starter
bmb063
2005 WK
Thats good news to hear! Another question I have is if I really need to replace it. Over a month ago I heard a sort of grinding noise only when starting, but this happened less than 5 times probably. Ever since it's gone away. Firestone said I have mud caked on the starter and the only way to fix it is to replace it: > $300 job.
Do I really need to replace it since it seems to be fine now? I don't want to risk it, but everything seems to be working fine. I am a little more focused on the bearings at the moment.
Also - I got an alignment and it still pulls to the left...the shop said it could be the bearings or wheels so there's nothing they can do. Slightly annoyed about that. I wouldn't have even got one if it wasn't going to fix the issue.
bmb063 is offline
bearing , bearings , brand , replacement , starter
