Removing front drive shaft. Will it still drive? - JeepForum.com
 6Likes
post #1 of 20 Old 07-05-2019, 10:30 AM Thread Starter
soonerck
soonerck's Avatar
2005 Grand Cherokee Laredo. There is an issue either in the front diff or I may have the torque converter issue. If I remove the front drive shaft, the front diff will still have moving parts but no force to it. I was hoping removing the front shaft might help me pinpoint my problem but I'm not sure if that would work. I'm no 4x4 expert by any means.
soonerck is offline
post #2 of 20 Old 07-05-2019, 11:01 AM
consumedbywater
No, it won't move. The transfer case doesn't lock up, so you'll just end up sending all the power through the disconnected front end.
underscore likes this.
consumedbywater is offline
post #3 of 20 Old 07-05-2019, 11:21 AM Thread Starter
soonerck
soonerck's Avatar
That was my worry. I remember locking my J80 to get it to move. Thank you.
soonerck is offline
post #4 of 20 Old 07-05-2019, 11:55 AM
TSEJEEPERS
TSEJEEPERS's Avatar
You can move it in 4wd low.
Enough to move it out of the garage any way. I would not drive it across town.
2005JGC likes this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 20 Old 07-09-2019, 12:43 PM Thread Starter
soonerck
soonerck's Avatar
No biggie, just my Tranny
turns out it's my crappy mercedes built transmission. Torque converter clutch assembly. $5000 to replace. No one will rebuild it. Thanks Jeep/Dahmler/Fiat
soonerck is offline
post #6 of 20 Old 07-09-2019, 01:14 PM
222Doc
222Doc's Avatar
thought they were made in the Indiana Transmission, usa.
soonerck likes this.
222Doc is offline
post #7 of 20 Old 07-09-2019, 02:13 PM
yzjwk
yzjwk's Avatar
2005 WK
$5K ? You can replace the whole transmission for less then that .. I would find a new shop.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 20 Old 07-10-2019, 10:09 AM Thread Starter
soonerck
soonerck's Avatar
that is the whole transmission. $1000 core charge. Tranny shops won't even order it until you drop off. They are on national backorder so I'm looking at 30 days minimum before they would likely even ship. The 4.7 and 5.7 have USA tranny's. My cheap jeep has the built to fail Mercedes tranny.
soonerck is offline
post #9 of 20 Old 07-10-2019, 10:10 AM Thread Starter
soonerck
soonerck's Avatar
soonerck is offline
post #10 of 20 Old 07-10-2019, 11:29 AM
underscore
2007 WK
I might be wrong but isn't the torque converter external to the trans? Either way I'd hardly call a single failure on a 15 year old vehicle "built to fail".
yzjwk likes this.
07 WK CRD//QDII//OME MD//OMG WTF BBQ [daily]
91 Celica GTFour RC [for sale]
underscore is offline
post #11 of 20 Old 07-10-2019, 12:54 PM
yzjwk
yzjwk's Avatar
2005 WK
^^ this .. W5J400 torque converter at RA is $300 . And in many ways I'd rather have a NAG1 then the 545
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #12 of 20 Old 07-10-2019, 01:46 PM
90grandoneer
90grandoneer's Avatar
2006 WK
X2....in most cases, a lot more flexibility. I have the 545RFE in the Jeep and 2 Hemi LX vehicles with the NAG1. I might be changing the conductor plate in the NAG1 in my 05 Hemi Magnum (limp mode) with only 87K on it. Have to do a little troubleshooting yet though. My 300C SRT8 has 168K on it and works perfectly, and it gets a lot of hard exercise almost daily.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS and HP tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads w/new valve seats, SRT Reps with 265/45&295/40X20's. Also 05 Hemi LX modded exactly like WK and Comp Cammed 06 300CSRT8.
90grandoneer is offline
post #13 of 20 Old 07-10-2019, 02:04 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yeah, the NAG has a good reputation for durability. Its not well suited to a V6 performance wise, however. Tons of complaints. The V8 version can handle tons of power but the V6 version uses less durable parts than the V8s I think.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #14 of 20 Old 07-10-2019, 06:34 PM
bener_m
Are you saying that they are using a different W5A580 (NAG1) in the CRD compared to the V8? I didn't think that was the case.
As far as I know, the 4.7 and 5.7 use US build NAG1, and the CRD uses German built W5A580 - same transmission, different country of origin. A lot of people have stated that the German built one is better, which is understandable considering the Germans designed it in the first place!
The NAG1/W5A580 is used in a lot of powerful cars, and the '580' refers to it being able to cope with 580lb-ft of torque.
http://etereman.com/blog/racing-tran...o-look-out-for
https://en.wikipedia.org/wiki/Merced...c_transmission
bener_m is offline
post #15 of 20 Old 07-11-2019, 06:06 AM
ggrassmid
2008 WK
The CRD, SRT8, and the 3.7v6 got the NAG1; the 4.7 and the 5.7 got the 545RFE.
Sometimes I want the gearing in the 545RFE in my CRD, NAG1 is 1:1 in 4th gear, the 545 is 1:1 in 3rd gear; leaving OD in a much better area. Though, it seems like the 545 isn't built to hold the torque and power of the SRT or the CRD... BUT WHY put it in the 3.7v6?
badgerwithhands likes this.
ggrassmid is offline
