Red lightning bolt and other issues - JeepForum.com
 2Likes
  • 1 Post By jtec
  • 1 Post By enkioferidu
post #1 of 13 Old 01-28-2020, 03:47 PM Thread Starter
enkioferidu
So as of yesterday I have been getting the red lightning bolt. This lead to the engine half cranking and stalling out. Randomly went out and started it again and it started right up.
This morning I went outside to start it to warm it up (19f in my neighborhood this morning) and it started right up. No lights or anything on. I went to hop in to drive to work and the check engine light was solid as well as the red lightning bolt. I drove it with no problems other than the lights. I did notice my temp gauge was stuck on cold and it took forever for my heat to get warm... Even after 10-15 minutes of letting it run before we got in it. I do have some codes, but nothing I've seen that has to do with temp or thermostat.
It never went to limp mode and as long as it starts it stays running just fine. I've looked at random sources and they all vary. Thought I'd ask the experts.
2007 Grand Cherokee Laredo 3.7l
IMG_20200127_165126_1580248039080.jpg   MVIMG_20200127_165123_1580248050124.jpg   IMG_20200127_165120_1580248061598.jpg   IMG_20200127_165117_1580248072308.jpg   IMG_20200127_165114_1580248103384.jpg
IMG_20200127_165111_1580248113950.jpg   IMG_20200127_165107_1580248121900.jpg   IMG_20200127_165104_1580248157364.jpg   IMG_20200127_165102_1580248166880.jpg   IMG_20200127_165059_1580248174838.jpg
enkioferidu is offline
post #2 of 13 Old 01-28-2020, 03:54 PM Thread Starter
enkioferidu
Here are the rest of the codes I am getting.
IMG_20200127_165053_1580248347067.jpg   IMG_20200127_165051_1580248357274.jpg   IMG_20200127_165048_1580248366374.jpg   IMG_20200127_165045_1580248377940.jpg   IMG_20200127_165042_1580248387738.jpg
IMG_20200127_165038_1580248403538.jpg   IMG_20200127_165036_1580248416913.jpg   IMG_20200127_165033_1580248428549.jpg   IMG_20200127_165024_1580248440211.jpg
post #3 of 13 Old 01-28-2020, 06:11 PM
jtec
jtec's Avatar
2014 JK Wrangler
P0607-ECU Internal Performance
U1402-Implausible Engine Temperature Signal Received
P2181-Cooling System Performance
thats enough to have me ask - jeep is STOCK no aftermarket BS - just like is was made?
Anyway there are your cooling codes.
jtec is offline
post #4 of 13 Old 01-28-2020, 09:52 PM
nvrdone
if it takes along time to warm up and never reaches correct operating temp, im thinking it may have a t'stat stuck in the open position. I had a similar problem with my 5.7 and after replacing 3 aftermarket t'stats, still had the problem. replaced it with a dealer part with the little tab pointed to the top. no more problems. might be worth a try.
nvrdone is offline
post #5 of 13 Old 01-28-2020, 10:13 PM
gspfunk
gspfunk's Avatar
2019 WK
More often than not, the red lightning bolt is due to a battery thatís on its way out. It will cause all kinds of codes and throw you off the scent. Have it tested with a battery tester to see if thatís your culprit.
19 Sting-Gray WK2 Trailhawk | Hemi | MRR | Ridge Grapplers
08 Silver WK1 SRT8
gspfunk is offline
post #6 of 13 Old 01-29-2020, 05:11 AM
caulk04
2008 WK
The red lightning bolt framed in brackets refers to throttle control system.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #7 of 13 Old 01-29-2020, 10:02 AM Thread Starter
enkioferidu
Thanks for the heads up guys. Just an update. Yesterday it sat all day while I was at work and when I started it up... No red lightning bolt and my temp gauge worked. This morning however same deal no temp gauge and red lightning bolt. Ordered a new thermostat. As for the battery being bad... Maybe it's less than a year old that being said I'll have it checked soon.
post #8 of 13 Old 01-29-2020, 10:03 AM Thread Starter
enkioferidu
Forgot to mention the only aftermarket thing so far is larger tires. Nothing else atm.
post #9 of 13 Old 01-29-2020, 10:41 AM
jtec
jtec's Avatar
2014 JK Wrangler
interesting - I suspected lighting, audio, a possible body damage issue and some type of prom, programmer, or something plugged into DLC.
The P0607 is most concerning. When you clear codes - will they all erase?
As mentioned charging system would be a place to start.. to easy a test inspection to ignore.
enkioferidu likes this.
jtec is offline
post #10 of 13 Old 01-29-2020, 11:04 AM Thread Starter
enkioferidu
They do clear without issue. I noticed after I bought my WK that one of the clips that hold 1 of the 3 connections to my computer will not snap in place. It stays put but I have noticed on occasion I can push it in a little further. I wonder if this could be causing the p0607 dtc? I can get a picture later to show you what I mean. It'd be great if there was a fix tho that as well.
gspfunk likes this.
post #11 of 13 Old 01-29-2020, 12:04 PM
gspfunk
gspfunk's Avatar
2019 WK
Correct, however a failing battery wreaks havoc with the electronics in these and has been known to light the dash up like a Christmas tree. Sometimes unrelated to whatís actually happening.
08 Silver WK1 SRT8
gspfunk is offline
post #12 of 13 Old 01-30-2020, 09:33 AM Thread Starter
enkioferidu
OkI will have it tested ASAP.
post #13 of 13 Old 01-31-2020, 08:15 AM
Th0r
2009 WK
Have you checked the ECM plugs/terminals?
I fought the red lightning bolt for a while. Along with other odd codes including my coolant temp. They weren't related to so I checked grounds, my battery, and pulled and inspected my ECM connections. I found out I had fluid in one of the plugs for the ECM. Dried it out, cleaned the connections and was good for a week before it came back. Popped the plug and, sure enough, fresh fluid. Tasted like coolant. Pulled up the schematics too see what all fed to that plug. Along with the coolant temp sensor on that branch, there was also the throttle control system, and the TCS terminals that were corroded and also where the coolant first pooled causing the "red bolt in brackets" light.
Turned out my coolant temp sensor had a plastic body can cracked. Coolant was forced into the sensor and wicked it's way through my wiring harness all the way to the ECM. Coolant pooled and corroded the connections in one of the 4 plugs (I think it was the orange one). I replaced the coolant sensor, cleaned the ECM, and had no issues since. I checked the ECM plug a week later and had only a small amount of coolant that finished wicking it's way there. Cleaned that up and it was still dry two weeks later.
Th0r is online now
