Rear view camera - JeepForum.com
 1Likes
  • 1 Post By dj_hp
post #1 of 7 Old 10-07-2019, 08:31 PM Thread Starter
b52srule
2007 WK
Rear view camera
My original radio/cd player/nav system has gone belly up. Blank screen, am only, nothing else. Iím replacing it with a Kenwood DNX 576X from Crutchfield. I lose U Connect, I can live with that but I also lose the rear view camera. Not good. Everything else will be retained.
Anyone out there have a work around or fix?
Len aka B52srule
b52srule is offline
post #2 of 7 Old 10-29-2019, 12:22 PM Thread Starter
b52srule
2007 WK
Interesting....the back up sensors still work without the cam.
Len aka B52srule
b52srule is offline
post #3 of 7 Old 10-29-2019, 05:10 PM
2005JGC
2005JGC's Avatar
2005 WK
Backup sensors work just fine, different system.
I am not an audio expert, but in the looking around and research I have done, very little seems to work with factory equipment. The factory sirius antenna... Nope. GPS antenna.
Nope... Factory bluetooth mic... Nope. Factory rear view camera... Nope.
You can get an aftermarket camera if your radio has the capability, and route the cable to the back. A license plate mount is the easiest. Personally I would try to find one that I could jury rig to work in the factory housing because it would, *could* look better. Nothing a dremel and some epoxy cannot make work half way decent.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #4 of 7 Old 11-02-2019, 02:59 PM
offroading.net
offroading.net's Avatar
2007 WK
Originally Posted by 2005JGC View Post
........ GPS antenna.
Nope... ....
Factory GPS antenna plugged straight into my Kenwood/Garmin headunit and worked fine.
Steve Wright
'07 Grand Cherokee Overland CRD
'16 Renegade Limited, Wifey Wagon
Previous Jeeps- 8 XJs, 3 KJs, 3 WJs, 2 TJ's & an MJ
offroading.net is offline
post #5 of 7 Old 11-02-2019, 04:27 PM
T1m
T1m's Avatar
2006 WK
Yes. Click on accessories and view the backup cameras available for it. The product description shows the rear camera as optional.
T1m is offline
post #6 of 7 Old 11-13-2019, 11:13 AM
dj_hp
2008 WK
Depending on which aftermarket stereo you get, you're most likely going to need iDatalink modules/harnesses. You'll lose Uconnect, but you'll retain backup camera, steering wheel controls, factory amp, etc.
I have this same exact problem right now, and from my research, you'll need the following according to Crutchfield's website (these are Canadian prices):
iDatalink Maestro RR Interface Module
iDatalink HRN-RR-CH1 Factory Integration Adapter
iDatalink HRN-AV-CH1 Factory Integration Adapter
Metra 40-EU10 Antenna Adapter
Quite a bit of $$ for adapters, but it's the only way to keep all factory features with an aftermarket deck. If you don't care about steering wheel controls, you could get away with just installing an aftermarket backup camera.
MC_wk likes this.
dj_hp is offline
post #7 of 7 Old 11-14-2019, 10:31 AM Thread Starter
b52srule
2007 WK
I believe those are the parts I used to install the Kenwood. I did lose the UConnect and back up camera. Neither Kenwood or Crutchfield have a fix for the cam. I found several thoughts on how to do a workaround on a few forums as well as some thoughts from Crutchfield. I finally has one installed locally. Crutchfield does provide outstanding tech support. I do like the new unit, heads and tails above the old unit. More bells and whistles than Iíll even need or figure out how to use.
Len aka B52srule
b52srule is offline
