Rear 6" spring - JeepForum.com
post #1 of 2 Old 05-02-2021, 07:22 AM Thread Starter
Dragoon400
Rear 6" spring
I'm having trouble locating a spring for my modified SL. Currently i'm running the SL coil and a spacer but id like to eliminate the spacer.
JBA doesn't seem to have them anymore? Anyone know where I can find a set?
Dragoon400 is offline
post #2 of 2 Old 05-11-2021, 02:15 PM
MA_Racing27
MA_Racing27's Avatar
Pretty sure you can only fine them used at this point. Or get coils that are for a different vehicle with similar mounting seats. I saw someone use 4 inch springs out of a JKU but our WK/XKs are heavier and he only got about 2 or 3 inches of lift in the rear. He modified the top and bottom spring seats to accommodate this. So it is doable just has to be the correct weight springs. I will be researching diff springs to do a SAS to my WK. I will not be using coil overs.
MA_Racing27 is offline
