Problems with ABS - JeepForum.com
post #1 of 11 Old 09-23-2019, 11:51 AM Thread Starter
Dag93
Problems with ABS
Hey Guys I was reaching out cause I am dealing with an issue I have yet to see. Currently I have my Ebrake, ABS, ESP, and traction control lights on at the same time. About a month ago I replaced most of my front end suspension components including my wheel hubs and ABS sensors. The past few weeks I have developed a loud click/popping upon exceleration from my front end. This is not a noise that is predominant during turns and I have no noticeable vibrations. My thoughts are that its either one of the CV axles up front or my front drive shaft? Is there any indication that a CV axle failure can result in an ABS code? I know a lot of CVs have tonner rings built in. Thanks for the input guys!
If it can't be fixed with Duct tape, it can't be fixed
Dag93 is offline
post #2 of 11 Old 09-23-2019, 12:13 PM
Rtbrjason
Rtbrjason's Avatar
2008 WK
Clicking usually ends up being cv’s. As for the lights, do you have any means of checking codes?
Are the lights on as soon as you start it or do they come on after you hit about 10-15 mph? If the former, I suspect abs sensor issue. Make sure they’re plugged in tight.
Rtbrjason is offline
post #3 of 11 Old 09-24-2019, 05:25 AM Thread Starter
Dag93
So unfortunately I do not have a scanner that can read ABS codes. I did notice that the lights cut on right around that 15Mph mark that you stated
Dag93 is offline
post #4 of 11 Old 09-24-2019, 09:08 AM
Raffish
2005 WK
You can get a $7 dongle and a free app to read codes...
Codes are a great way for someone on the other side of earth to start spitballing and help you fix your ride...
(Suggest getting something that will read TCM and other modules)
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, MBRP SS, 250xxxkms
Raffish is offline
post #5 of 11 Old 09-26-2019, 02:39 PM Thread Starter
Dag93
While I'm looking into the ABS is there any clear way besides the clicking to check CV joints? I looked at the joints and none have clear rips in the boots.
Dag93 is offline
post #6 of 11 Old 09-26-2019, 03:18 PM
powerstroke01
powerstroke01's Avatar
2005 WK
Get a BT or USB OBD2 dongle and buy this app.
http://jscan.net/
edit: its the best thing since sliced bread!!!!
Jeepers do it in the mud. ;)
powerstroke01 is offline
post #7 of 11 Old 09-27-2019, 09:24 AM
yzjwk
yzjwk's Avatar
2005 WK
CV's themselves usually won't cause those lights to come up unless the CV is bad enough that it took out the hub assembly too. The toner rings on a WK are inside the hub assembly.
You can check for a major failure of the cv by sliding under and checking for movement at either end (it's happened to me when the diff side had almost 1" of movement and I had a clunking at acceleration and de-acceleration) but usually the clicking is caused by the CV just wearing out.
You should have the ABS codes read because that will tell you what wheel signal had failed so you're not guessing. Any corner garage should do that for you .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 11 Old 09-27-2019, 02:34 PM Thread Starter
Dag93
Thanks for the input guys, I'll look into those scanners and my CVs. For now I stop by O'Reilly's who actually has an ABS scanner and got C2200 which points to the antilock break module? Anyone else run into this?
Dag93 is offline
post #9 of 11 Old 09-27-2019, 07:29 PM
Rtbrjason
Rtbrjason's Avatar
2008 WK
Just had the same thing happen to me (c2200). Not sure what caused it though. I did replace brake fluid about a week before it happened. It’s gone away on its own so far.
post #10 of 11 Old 10-07-2019, 01:10 PM Thread Starter
Dag93
I appreciate the replys, I wanted to give it some time to see what happened. The lights still show on my Jeep stay on the entire time after I hit 10 mph
Dag93 is offline
post #11 of 11 Old 10-08-2019, 04:33 PM
JustCallLance
2006 WK
We had a similar issue on our 2006 WK. I would doubt that you would have the same issue, but it's worth a check just to be sure. We had a very small radiator leak above the passenger side wheel. It was small enough that it only leaked when hot/under pressure, and never leaked enough to leave a spot on the driveway, or even smell of anti-freeze. It WAS enough to drip onto and affect the brake rotor. Not only did it intermittently sound like the brakes were grinding, it would take out a new ABS sensor within a few weeks.
Again, it's probably not likely, but you never know.
JustCallLance is offline
