Possessed Headlight - JeepForum.com
post #1 of 4 Old 11-05-2007, 06:46 PM Thread Starter
cariboulou
Possessed Headlight
I have a Jeep Grand Cherokee 2006. When I turn my lights on to second denton (normal headlight operation), about 10 minutes into driving the lights become possessed, flash on and off and they completely turn off. This only happens on the second setting. If I turn the lights onto the third denton (automatic headlight operation) the lights work fine, no flashing, no alien possessions. Has anyone else had this happen, if so, please advise. It's driving my husband and I crazy. Thank you.
cariboulou is offline
post #2 of 4 Old 11-05-2007, 08:19 PM
menoche
menoche's Avatar
2007 WK
that sound to me like an electrical contact problem.
Do you have access to pressurized air? if so try airing the surrounding of the contact.
Another thing you can try in cleaning it by sending contact cleaner (make sure you have a rag to pick up the liquid then sned more air in there to dry it up.
Phil
menoche is offline
post #3 of 4 Old 11-29-2007, 11:34 AM
pillzny
Not sure if you've figured this out but I have aftermarket headlights. About 6 months in, my headlights would shut off when I would click the knob to turn them on. I was on my daytime running lights until they stopped working all together this Thanksgiving weekend. Jeep just let me know today that the comp is sensitive and it makes the electrical system wacky. Not sure if this helps you any... considering you've changed your bulbs
pillzny is offline
post #4 of 4 Old 11-29-2007, 12:53 PM
merlinTec
merlinTec's Avatar
Hi
I have one in the work shop now for the same fault technical have told me to replace the ignition switch as this is a known issue. However this has not fixed the fault on this on so will look some more tomorrow. Can you tell me does all the lights go out or is it just the head lights. My one is all the lights.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
2005 Grand Cherokee is Possessed Dixierambler WK Grand Cherokee & XK Commander Forum 12 09-11-2008 09:47 PM
Grand Cherokee possessed craniusmaximus WJ Grand Cherokee Forum 4 07-26-2007 08:05 PM
98 Grand Possessed! Help sgtgrannyx4 ZJ Grand Cherokee Forum 9 10-31-2006 01:17 AM
98 Grand Possessed! Help sgtgrannyx4 ZJ Grand Cherokee Forum 2 10-26-2006 09:33 PM
Help! My Jeep is Possessed!! jaharris ZJ Grand Cherokee Forum 1 08-29-2006 09:39 AM
