Oil fumes in the cabin - '08 CRD - JeepForum.com
 3Likes
  • 1 Post By Brit30-06
  • 1 Post By ggrassmid
  • 1 Post By SteveROntario
post #1 of 8 Old 03-14-2019, 05:16 PM Thread Starter
robert defranzo
Hi yall, Im new to the jeep CRD platform just picked up a 2008. I have had diesels for the past 15 years(VW). Noticed that oil vapor odor when engine is warm and idling for a long period of time so Im going to try this simple mod to see how it works. First I removed the passenger w/wiper, then I removed the plastic air intake on the cowl. I flip it upside down and used duct tape block off the forward facing slots. I also blocked off a small section of the upper, inboard slots. The tape is on the inside of the cowl and can be seen in the picture as the tan area. Going to give it a try for a few months and report back.
robert defranzo is offline
post #2 of 8 Old 03-14-2019, 05:27 PM
moonvan
2008 WK
I had a smell like that when i got mine, it kind of smelled like fresh asphalt. It turned out to be a leaky fuel filter which was a pretty easy and cheap fix.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #3 of 8 Old 03-14-2019, 06:17 PM
Brit30-06
2008 WK
Hi
Check the 'plumbing' from the ccv to the turbo intake. A leak will give you oil vapour smell.
Brit.
underscore likes this.
Brit30-06 is offline
post #4 of 8 Old 03-15-2019, 09:07 AM
underscore
2007 WK
Also pull off the engine covers and look for an injector leak, those are pretty smelly too.
07 WK CRD//QDII//OME MD//OMG WTF BBQ [daily]
91 Celica GTFour RC [for sale]
underscore is offline
post #5 of 8 Old 03-15-2019, 12:33 PM
ggrassmid
2008 WK
Most of the good answers are already taken... dang it. I'm just tardy to the party now
badgerwithhands likes this.
ggrassmid is online now
post #6 of 8 Old 03-15-2019, 05:47 PM
Walt
2008 WK
....and check the front differential vent hose termination on the firewall in the same area as the fresh air intake.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #7 of 8 Old 03-15-2019, 06:13 PM
SteveROntario
The grommet where the electrical cabling goes into the cab can come loose and when that happens about all you can do is stuff a rag in the hole. If somebody has modified the crank venting that is likely the problem. Lastly, I think I bent the rear hatch in my rig a couple weeks ago. They are pretty flimsy where the flipper glass is located...I now have exhaust fumes coming into the vehicle after trying to force the hatch down onto a large box.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #8 of 8 Old 03-19-2019, 01:29 PM
terrasmak
2007 WK
Injector seals, but that is more of an exhaust smell
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
How to change the oil temperature and/or oil pressure switches/senders/sensors dudesqueak WK Grand Cherokee & XK Commander Forum 2 12-01-2018 01:49 PM
Any CRD owners use an Oil Extractor? Fumoto? TyeRant WK Grand Cherokee & XK Commander Forum 10 10-05-2018 03:24 PM
CRD, how often do you check oil level? SteveROntario WK Grand Cherokee & XK Commander Forum 9 09-18-2018 09:50 AM
3.0 CRD length of oil dipstick? Lightning_650 WK Grand Cherokee & XK Commander Forum 7 01-02-2018 03:06 PM
