Octane requirement - JeepForum.com
post #1 of 8 Old 03-04-2020, 07:08 PM Thread Starter
5280mike
Octane requirement
Howdy y’all. Recently purchased an 06 commander 5.7 and owners manual calls for 89 octane. I’m in Colorado and it goes from 87 to 91. I’ve read because of altitude 87=89 however just want to know if anyone has legit feedback on this. Do I use 91 since no 89?
5280mike is offline
post #2 of 8 Old 03-04-2020, 07:48 PM
caulk04
2008 WK
You can run 87 in them just fine. The pcm will pull timing if it knocks. You need a little more octane for max performance though.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 8 Old 03-05-2020, 08:59 AM
90grandoneer
90grandoneer's Avatar
2006 WK
Welcome to the forum. I'd say that it also depends on the altitude you drive at. I am at about 3000 ft. and, until I raised my compression ratio, I would run 87 in the winter and in the high (100-110*) summer temperatures, I alternately run 87/91 or all 91 depending on the type driving I was doing. Before the ratio change, when I traveled to altitudes above about 5000 ft. I'd even run 85. Some of my best fuel economy was achieved at or above 5000 ft. when running 85.
Like caulk04 says, the PCM will pull timing as needed so, depending on your altitude, you may want to experiment a little and see which octane works best for you and your driving conditions.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, AFE Air Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS and HP tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads w/new valve seats, SRT Reps with 265/45&295/40X20's. Also 05 Hemi LX modded exactly like WK and Comp Cammed 06 300CSRT8.
90grandoneer is offline
post #4 of 8 Old 03-05-2020, 06:47 PM Thread Starter
5280mike
Cool. Definitely appreciate the input. I’m mostly in Denver so above 5000 feet.
5280mike is offline
post #5 of 8 Old 03-06-2020, 12:08 PM
90grandoneer
2006 WK
Originally Posted by 5280mike View Post
Cool. Definitely appreciate the input. Iím mostly in Denver so above 5000 feet.
Most places I've been that are 5000 feet or above have 85 instead of 87. Do you have 85 in the Denver area? That must be what the "5280" in your screen name is all about??
post #6 of 8 Old 03-06-2020, 03:38 PM
SillyDude
2009 WK
This is fun. My name is Mike and I live in Denver too!
Hi 5280 (mile high city -- nickname for Denver) Mike
'09 JGC Limited, 5.7 Hemi, unmolested
2020 JGC SRT
SillyDude is offline
post #7 of 8 Old 03-06-2020, 04:10 PM
90grandoneer
2006 WK
You guys are silly, dude......Mike, LOL!!
post #8 of 8 Old 03-07-2020, 05:35 PM Thread Starter
5280mike
Yep I’m in Denver. Everywhere here is 85, 87, 91.
5280mike is offline
