No trailer lights - JeepForum.com
 1Likes
  • 1 Post By rokrau
post #1 of 3 Old 07-06-2019, 01:26 AM Thread Starter
rokrau
2008 WK
No trailer lights
Got stranded on the highway when all my trailer lights went out. Checked Fuse #6 and exchanged with the one from the rear seat power outlets but no change and the power outlet still works with the suspected bad fuse. I have a 5 pin out and my boat trailer uses a 4 pin connector, my adapter is 1month old and worked flawlessly to this day.
I put in a brand new marker light right before getting on the highway. Not sure if there is a short there but it did work when I started and 10 miles into the trip the lights are completely off.
I am at loss where to check next and any help is greatly appreciated.
Thanks!!!
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #2 of 3 Old 07-06-2019, 09:38 PM
SteveROntario
Reach up and dig around until you find the 4-way connector, it will be close to the 7-way. The trailer fuses are separate from the vehicle fuses so that you don't lose lights on the Jeep due to a trailer problem but it seems to me you have a bad ground. If you have a hinged trailer maybe you lost the ground there. I've installed jumpers around the hinge to deal with that.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #3 of 3 Old 07-07-2019, 01:14 AM Thread Starter
rokrau
2008 WK
Thanks Steve!
I had a short in one of my marker lights that was intermittent and caused Fuse #19 in the front Fuse box to blow. This is a 10A but last night I was too tired to figure this out. Repaired everything today and hopefully back on the road tomorrow.
Again thanks for your help.
BadExample likes this.
rokrau is offline
