New upper control arms (Rocky Road Outfitters) + 2 inch lift = Front end alignment? - JeepForum.com
 5Likes
  • 3 Post By yzjwk
  • 2 Post By 2005JGC
post #1 of 10 Old 09-22-2020, 11:46 AM Thread Starter
HankyD
Hey guy,
So as the title suggests, I've gone ahead with a 2 inch lift on my 08 WK CRD and opted to do the job properly with upgraded upper control arms by Rocky Road Outfitters.
I didn't have any alignment issues prior to beginning this project.
From what I understand, a 2 inch lift alone doesn't necessarily mean I need an alignment. But in this instance, the stock upper control arms were replaced with arms that can accommodate the proper articulation that comes with adding a 2 inch lift on these models.
I think the answer is no, but I just want to make sure.
Thanks again.
HankyD is offline
post #2 of 10 Old 09-22-2020, 01:31 PM
drew54
2006 WK
Maybe, maybe not.
You could find a place that does free alignment checks.
Some tire shops will offer this. If you're not in range, then you'll know.
drew54 is online now
post #3 of 10 Old 09-22-2020, 02:53 PM
yzjwk
yzjwk's Avatar
2005 WK
Originally Posted by HankyD View Post
Hey guy,
Thanks again.
The WK is IFS. Anytime you change the height, you need an alignment.
acabtp, underscore and 2005JGC like this.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is online now
post #4 of 10 Old 09-22-2020, 05:10 PM
2005JGC
2005JGC's Avatar
2005 WK
As yzjwk said... through the suspension travel, your alignment angles change being IFS. So if you change the ride height of the vehicle, your alignment angles are not where they should be at the new ride height. You need an alignment! A straight axle, just crank that drag link adjuster until the steering wheel is straight and send it. Not so much with IFS.
yzjwk and acabtp like this.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #5 of 10 Old 09-22-2020, 10:34 PM Thread Starter
HankyD
Great to know this information, I don't know too much about front ends, alignments, etc. I was of the belief that I would be fine (based on internet searches).
Thanks again!
HankyD is offline
post #6 of 10 Old 09-24-2020, 11:15 AM
nomercy346
2008 WK
Mine drove like crap after the lift before getting it aligned. Couldnít hold a straight line over the smallest bumps.
With the IFS you need the alignment once you touch ride height or the LCA mounts. I believe you could probably replace the ucas by themselves without getting it aligned as they donít have any adjustment.
Sent from my iPhone using Tapatalk
08 WK Limited CRD
14 RAM 1500 Hemi, CCSB
96 ZJ Limited 5.2 - sold
nomercy346 is offline
post #7 of 10 Old 09-24-2020, 12:05 PM
3Recon
2009 WK
You might not notice if your trail running or on loose surfaces but pick up the speed and city driving you more then likely just scrubbing off dollars on your tires.
If your adding wheel spacers in my option should be fine but in the end it's up to you how it fills. Ask your alignment person on what's might be needed after adding. It'll take a few miles to get accustom to the wider stance.
3Recon is offline
post #8 of 10 Old 09-26-2020, 08:22 AM
Th0r
2009 WK
You NEED an alignment. Lifting an IFS suspension really knocks things out of whack.
Ask to speak to the tech, and let him know if he's having issues with Camber that he can sacrifice Caster to get Camber in the green. If that is needed, and you are running a tire size larger the forum's recommendations for your lift, you may need to trim a little material from the inside of your front bumper.
Th0r is offline
post #9 of 10 Old 09-28-2020, 11:09 AM
jeepers_2020
jeepers_2020's Avatar
2005 WK
Nice, I was thinking of adding a 2" lift to mine as well so good to know I don't need to do a wheel alignment. I just had the control arms, tie rods, CV joints, etc. replaced on my vehicle. So definitely had to do a wheel alignment.
jeepers_2020 is offline
post #10 of 10 Old 09-28-2020, 11:11 AM
jeepers_2020
2005 WK
I only read the top post, and I just noticed that everyone was saying you needed a wheel alignment... good to know!
